node-red-contrib-alphacate 1.1.0
Node-RED node for calculating technical analysis for stock trading
npm install node-red-contrib-alphacate
For calculating technical indicators for stock trading.
Designed to work seamlessly with Alpaca via node-red-contrib-alpaca or node-red-contrib-alpaca-simple.
Based on npm package alphacate, link to GitHub for more information: https://github.com/codeplayr/alphacate.
NOTE: The package.json calls for a fork of the above mentioned repository as there were a couple fixes that had to be made to the original code, https://github.com/mdkrieg/alphacate
  • Connects seamlessly with Alpaca's getBars function
  • Calculate several indicators at once
  • Calculate several tickers' data at once
List of supported indicators:
  • ATR - AverageTrueRange
  • BB - BollingerBands
  • EMA - ExponentialMovingAverage
  • LWMA - LinearlyWeightedMovingAverage
  • MACD - MovingAverageConvergenceDivergence
  • MFI - MoneyFlowIndex
  • OBV - OnBalanceVolume
  • RSI - RelativeStrengthIndex
  • SMA - SimpleMovingAverage
  • SMMA - SmoothedMovingAverage
  • SO - StochasticOscillator
  • ROC - RateOfChange
  • WMA - WeightedMovingAverage
Instructions
There are two valid options for the format of the incoming msg.payload.
First option is a single array of bars:
msg.payload = [
        closePrice,
        openPrice,
        highPrice,
        lowPrice,
        volume
Second option is an object of tickers that each contain an array of bars as outlined above:
msg.payload = {
    TICKER1:[
        Array of Bars
    TICKER2:[
        Array of Bars
Options can be left as default or assigned through the configuration panel or passed in as msg.options.
Available options are:
msg.options = {
  "ATR": { "periods": 20 },
  "BB": { "periods": 20 },
  "EMA": { "periods": 12, "emaResultsOnly": false, startWithFirst": false },
  "LWMA": { "periods": 20 },
  "MACD": { "fastPeriods": 12, "slowPeriods": 26, "signalPeriods": 9 },
  "MFI": { "periods": 14 },
  "OBV": {},
  "RSI": { "periods": 14 },
  "SMA": { "periods": 10 },
  "SMMA": { "periods": 20 },
  "SO": { "periods": 14, "smaPeriods": 3 },
  "ROC": { "periods": 14 },
  "WMA": { "periods": 14 }
Release Notes
1.1.0 - added ability to change calculation settings in both config and documented in the help the method of doing it in msg.options object
1.0.1 - documentation and cleanup
1.0.0 - initial release
TODO / Roadmap
  • !!! Add ability to change calculation settings / options
  • Include examples
  • Create options to customize input data scheme
  • ^---(similarly) Create options to connect seamlessly to other data sources (alphavantage, finnhub, polygon, etc)
  • Add more indicators that can be calculated from OHCLV bars:
  • ---- AD (Accum/Dist)
  • ---- WPR (Williams % R)
Version: 1.1.0
Updated 4 years, 9 months ago
4 in the last week
  • stocks
  • stock market
  • trading
  • technical analysis
  • technical indicators
