node-red-contrib-alexa-remote2-applestrudel 5.1.1
node-red nodes for interacting with alexa
npm install node-red-contrib-alexa-remote2-applestrudel
npm downloads
Forked from cakebake/node-red-contrib-alexa-remote-cakebaked which was forked from 586837r/node-red-contrib-alexa-remote2 to keep dependencies up to date.
This is a collection of Node-RED nodes for interacting with the Alexa API. You can emulate routine behaviour, control and query your devices and much more!
All functionality is from alexa-remote2. The goal is to expose all of its functionality in node-red nodes.
Migration
In case you've already installed Node-RED nodes from alexa-cakebaked or alexa-remote2 the installation won't work due to conflicting names. You have 2 options:
Command Line
node-red admin remove node-red-contrib-alexa-remote2
node-red admin remove node-red-contrib-alexa-cakebaked
node-red admin install node-red-contrib-alexa-remote2-applestrudel
Node-RED UI
  1. Export all of your flows to a file (Menu -> Export -> all flows -> Download)
  2. Delete all flows (Double Click on each Tab -> Delete)
  3. Delete configuration node alex-remote-account node (Menu -> Configuration Nodes) and write down settings (Cookie path, refresh time)
  4. Deploy empty state
  5. Uninstall node-red-contrib-alexa-remote2 or node-red-contrib-alexa-cakebaked (Menu -> Manage Palette -> Palette -> Nodes -> remove)
  6. Search and install node-red-contrib-alexa-remote2-applestrudel
  7. Reimport all flows from file (Menu -> Import -> Clipboard -> select a file to upload)
  8. Restart Node-RED
Setup
  1. Drag an Alexa Routine node into your flow.
  2. Create a new Account by pressing the edit button at the right side of the Account field.
  3. Choose a Service Host and Page and Language depending on your location. For example:
    Service Host Page Language
    USA pitangui.amazon.com amazon.com en-US
    UK alexa.amazon.co.uk amazon.co.uk en-UK
    GER layla.amazon.de amazon.de de-DE
    FR layla.amazon.de amazon.fr de-DE
    ITA alexa.amazon.it amazon.it it-IT
    AUS alexa.amazon.com.au amazon.com.au en-US
    ES alexa.amazon.es amazon.es es-ES
    BR alexa.amazon.com.br amazon.com.br pt-BR
  4. Set This IP to the ip of your Node-RED server
  5. Enter a File Path to save the authentication result so following authentications will be automatic.
  6. Add the new Account.
  7. Deploy
  8. Follow the url you see in the node status
  9. Log in, wait until you see the node status ready
  10. Write "Hello World!" in the Alexa Routine node text field.
  11. Select a device in the Alexa Routine node devices field.
Now trigger the Alexa Routine Node with any message and your Alexa will say "Hello World!". (Hopefully!)
Version: 5.1.1
Updated 4 months, 1 week ago
Rating: 4.5 28
769 in the last week
  • alexa-remote-account
  • alexa-remote-init
  • alexa-remote-event
  • alexa-remote-smarthome
  • alexa-remote-routine
  • alexa-remote-echo
  • alexa-remote-other
  • alexa-remote-list
  • alexa remote
  • alexa
  • echo
  • fkhr79
  • Julian Wiche
  • Murilo
  • DanPatten
  • jonferreira
  • abstract-entity
  • nathan1987
  • nana4rider
  • George Talusan
  • Marian T.
