node-red-contrib-airthings 0.1.0
Node-RED nodes for the Airthings Consumer API — sensor readings and Renew air purifier control
npm install node-red-contrib-airthings
Buy Me A Coffee
Built and maintained independently. If this saves you time, a coffee keeps it alive.
Your air quality data. Your automations. Fully wired into Node-RED.
Node-RED nodes for the Airthings Consumer API — poll sensor readings from your Airthings devices and control the Renew air purifier directly from your flows.
See it in action
Poll temperature → boost the purifier when air quality drops. Confirm the state before and after.
The flow above reads sensor data on a schedule, runs it through a function node that checks temperature, sets the Renew to BOOST or AUTO accordingly, then confirms the new state with a get-state node — all in a handful of wires.
Node Description
airthings-config Shared credentials (Client ID + Secret)
airthings-sensors Fetch latest sensor readings from your devices
airthings-devices List all devices connected to your account
airthings-renew-get Get the current mode of a Renew air purifier
airthings-renew-set Set the mode of a Renew air purifier
Setup
1. Create an API client
Go to consumer-api-doc.airthings.com/dashboard and create an OAuth client. Copy the Client ID and Client Secret.
2. Add the config node
In Node-RED, add an airthings-config node and enter your Client ID and Client Secret. Account ID is optional — it will be auto-detected from your account.
3. Add nodes to your flow
All nodes take any input message as a trigger. Sensor data and device state are returned on msg.payload.
Node reference
airthings-sensors
Fetches the latest readings from your Airthings devices. Select which devices to include using the checkboxes in the node editor (all checked = fetch all). Each device is queried individually so a single unresponsive device won't block the rest.
Inputs
Property Type Description
payload any Triggers a fetch
unit (optional) string "metric" (default) or "imperial"
serialNumbers (optional) string[] Override the node's device selection at runtime
Output — msg.payload is a flat object keyed by serial number:
  "2930001150": {
    "sensors": { "co2": 642, "temp": 27.4, "humidity": 51, "voc": 105, "pressure": 1010 },
    "recorded": "2026-06-28T17:42:50",
    "batteryPercentage": 100
  "4100000915": {
    "sensors": { "pm25": 3.0 },
    "recorded": "2026-06-28T17:50:32",
    "batteryPercentage": null
  "2930024040": { "error": "API error (504)..." }
Devices that fail individually appear with an error key — the rest still populate normally. To act on a specific sensor value in a downstream Switch or Function node:
msg.payload["2930001150"].sensors.temp  // → 27.4
msg.payload["4100000915"].sensors.pm25  // → 3.0
airthings-devices
Lists all devices on the account, including their sensor capabilities. Useful for discovering serial numbers.
Output — msg.payload:
  "devices": [
      "serialNumber": "4200012345",
      "name": "Living Room",
      "type": "WAVE_PLUS",
      "home": "Home",
      "sensors": ["co2", "humidity", "pressure", "radon", "temp", "voc"]
airthings-renew-get
Gets the last reported mode of a Renew (AP_1) air purifier. Select your Renew device from the dropdown in the node editor (only AP_1 devices are shown).
Input — set msg.serialNumber at runtime to override the node's selected device.
{ "mode": "AUTO" }
{ "mode": "MANUAL", "fanSpeed": 3 }
airthings-renew-set
Sets the operational mode of a Renew (AP_1) air purifier. Select your device from the dropdown in the node editor. The command is forwarded asynchronously — use airthings-renew-get to confirm the device has applied it.
Input — msg.payload can be:
  • A mode string: "AUTO", "OFF", "SLEEP", "BOOST", or "MANUAL"
  • An object: { "mode": "MANUAL", "fanSpeed": 3 } (fanSpeed 1–5 required for MANUAL)
Set msg.serialNumber at runtime to override the node's selected device.
Mode Description
OFF Turn off
AUTO Automatic — adjusts speed based on built-in PM sensor
SLEEP Quiet low speed for 8 hours (23 dB)
BOOST Maximum speed for 60 minutes
MANUAL Fixed fan speed — set fanSpeed 1 (quietest) to 5 (highest)
Output — msg.payload echoes the applied command:
Example: boost the Renew when it's too warm
Wire up: inject (every 5 min) → airthings-sensors → function → airthings-renew-set
In the Function node:
const sn = "2960000310"; // Tv Cabinet VIEW_PLUS · 2960000310
const temp = msg.payload[sn]?.sensors?.temp;
if (temp === undefined) return null; // device didn't respond — do nothing
msg.payload = temp > 20 ? { mode: "BOOST" } : { mode: "AUTO" };
return null drops the message silently if the sensor didn't respond, so the Renew is never touched on a bad reading. Swap the serial number for whichever of your devices has a temperature sensor.
Requirements
  • Node.js 14 or later
  • Node-RED 2.0 or later
MIT
Support this project
I built and maintain this as a personal project in my own time. If it's useful to you and you'd like to help keep it alive, a coffee goes a long way — it's the most direct way to support independent open-source work like this.
☕ Buy me a coffee
Bug reports, feature requests, and pull requests are all welcome on GitHub.
Version: 0.1.0
Updated 4 months, 2 weeks ago
150 in the last week
  • airthings-config
  • airthings-sensors
  • airthings-devices
  • airthings-renew-get
  • airthings-renew-set
  • airthings
  • air quality
  • air purifier
  • iot
