node-red-contrib-airtable-http 0.1.0
Node-RED node to interact with Airtable via HTTP requests
npm install node-red-contrib-airtable-http
This is my first repo and i also vibe coded almost all of it, so use at your own risk! 😅
A Node-RED node to interact with Airtable via direct HTTP requests (no airtable.js dependency).
Operations: list, get, create, update, delete, or variable (use msg.operation)
List Options: filter by view, fields, formula, and sort
Lightweight (Axios-based)
Full control over HTTP headers, pagination, and error handling
Prerequisites
Node.js v14 or later
Node-RED v2.0 or later
An Airtable API key
Your Airtable Base ID (e.g. appXXXXXXXXXXXXXX)
From your Node-RED user directory (~/.node-red)
Then restart Node-RED and add the Airtable HTTP node from the palette.
API Key: In Node-RED, go to Manage Palette → Credentials → Airtable HTTP and set your Airtable API key.
Base ID: Enter your Airtable Base ID (e.g. appXXXXXXXXXXXXXX).
Table Name: Name of the table in Airtable (e.g. Tasks).
Operation:
list: Retrieve multiple records
get: Retrieve a single record by ID
create: Create a new record (use msg.payload.fields)
update: Update an existing record by ID (use msg.payload.fields)
delete: Delete a record by ID
variable: Choose operation at runtime via msg.operation
List Operation Settings
View: (optional) name of the view to fetch
Fields: comma-separated list of fields to return (e.g. Name,Amount)
Filter By Formula: Airtable formula (e.g. {Status} = 'Done')
Sort Field & Direction: sort key and order (asc or desc)
Usage Examples
  1. List Records
{ "id": "airtable1", "type": "airtable-http", "baseId": "appXXXXXXXXXXXXXX", "tableName": "Tasks", "operation": "list", "view": "Grid view", "fields": "Name,Status,Due", "filterByFormula": "{Status} = 'Open'", "sortField": "Due", "sortDirection": "asc" }
  1. Get a Record
{ "id": "airtable2", "type": "airtable-http", "baseId": "appXXXXXXXXXXXXXX", "tableName": "Tasks", "operation": "get", "recordId": "recXXXXXXXXXXXXXX" }
  1. Create a Record
// In a function node before airtable-http: msg.payload = { fields: { Name: 'New Task', Status: 'Open' } }; return msg;
Set Operation to create on the Airtable HTTP node.
  1. Update a Record
msg.recordId = 'recXXXXXXXXXXXXXX'; msg.payload = { fields: { Status: 'Done' } }; return msg;
Set Operation to update.
  1. Delete a Record
msg.recordId = 'recXXXXXXXXXXXXXX'; return msg;
Set Operation to delete.
  1. Variable Operation
msg.operation = 'create'; msg.payload = { fields: { Name: 'Dynamic Task' } }; return msg;
Select Operation = variable in the node.
Error Handling
Errors are sent to the Node-RED debug console.
HTTP status and error messages are included in msg.error.
MIT © Your Name
Version: 0.1.0
Updated 1 year, 6 months ago
91 in the last week
  • airtable
  • http
