node-red-contrib-airtable 0.1.2
A collection of Node-RED nodes for Airtable.
npm install node-red-contrib-airtable
Japanese
NPM
Pre-requisites
The node-red-contrib-airtable requires Node-RED to be installed.
Restart your Node-RED instance, the airtable node appears in the palette and ready for use.
Overview
node-red-contrib-airtable performs the following processing.
  • select - Get a list of tables.
  • find - Get the specified record in the table.
  • create - Create a new record in the table.
  • update - Update a record in a table. update will only update the fields you specify, leaving the rest as they were.
  • replace - Update a record in a table. replace will only update the fields you specify and clear all unspecified field values.
  • delete - Delete a record in a table.
Acknowledgements
The node-red-contrib-airtable uses the following open source software:
See license (Apache License Version 2.0).
Contributing
Both submitting issues to GitHub issues and Pull requests are welcome to contribute.
Developers
If the developer wants to modify the source of node-red-contrib-airtable, run the following code to create a clone.
cd ~\.node-red\node_modules
git clone https://github.com/joeartsea/node-red-contrib-airtable.git
cd node-red-contrib-airtable
npm install
Version: 0.1.2
Updated 6 years ago
License: Apache
20 in the last week
  • airtable
  • airtable out
  • airtable
