node-red-contrib-air-monitor-qingping 1.1.2
Air Monitor plugin for QingPing Glass Monitor that exposes CO2, TVOCs, Temperature, Humidity and PM2.5
npm install node-red-contrib-air-monitor-qingping
Instalation
Node-Red air-monitor node that exposes multiple air quality metrics.
Supported metrics:
  • PM2.5
  • CO2
  • TVOCs
  • Temperature
  • Humidity
Use the configuration dialog to set:
  • IP Adress of the device (required)
  • API Token of the device (required)
  • Refresh rate (defaults to 5 seconds)
Optionally, all metrics could be enabled/disabled. All are enabled by default.
Get the token & IP address
You can check the following to get the device's information that you need in order to properly setup the node.
Version: 1.1.2
Rating: 5.0 2
1 in the last week
  • air-monitor
  • qingping
  • airmonitor
  • xiaomi
  • glassmonitor
  • cgs1
