node-red-contrib-ai-flow-builder 0.1.2
Node-RED sidebar chat panel powered by OpenAI / Anthropic that understands and edits your flows.
npm install node-red-contrib-ai-flow-builder
AI chat sidebar for Node-RED โ€” chat with OpenAI or Anthropic right inside the editor. The assistant sees your flow(s), reads installed palette modules, accepts images/files, and can apply code changes directly to your canvas โ€” the active tab or any other tab.
Status: 0.1.2 โ€“ feature complete, pending first publish.
Highlights
  • ๐Ÿ’ฌ Right-sidebar chat with streaming responses (SSE).
  • ๐Ÿค– OpenAI and Anthropic โ€” pick any model available from your account (free-text field with live suggestions + a direct link to each provider's official model list).
  • ๐Ÿ”’ API keys live in a Node-RED config node (encrypted flows_cred.json). They never reach the browser.
  • ๐Ÿ“Ž Multipart upload of images, PDFs, JSON/text โ€” with an in-chat viewer (lightbox + text pane + PDF embed).
  • ๐Ÿง  Flow context auto-attached: active tab JSON + selectable additional tabs through a compact multi-select + full catalog of every registered node type (grouped by module, core nodes flagged) so the AI only suggests things you actually have installed.
  • ๐Ÿ›ก๏ธ Built-in sanitizer strips credentials, password, token, secret, apiKey, auth, and every ${env.*} reference before anything leaves your machine.
  • โœ๏ธ Copy & Apply buttons per code block. Apply targets the active tab, any other tab, a specific node, a subflow, or a brand-new tab. Preview before apply. Undo via editor Ctrl+Z.
  • ๐Ÿ—‚๏ธ Conversations persisted under <userDir>/ai-flow-builder/ โ€” new / reopen / delete. Delete also removes the attachments folder.
From the Node-RED palette:
Manage palette โ†’ Install โ†’ node-red-contrib-ai-flow-builder
The palette manager loads the new nodes immediately โ€” no restart required. Reload the editor (Ctrl+Shift+R) and the AI Chat tab appears in the right sidebar.
Manual install (requires a Node-RED restart):
node-red-restart        # or however you run your instance
Configure providers
  1. Open the AI Chat sidebar. Next to the provider dropdown you have two buttons:
    • + โ€” create a new provider
    • โš™ โ€” edit the currently selected one
  2. In the dialog: pick OpenAI or Anthropic, choose/type a model (free-text field, autocomplete suggestions + a link to the official model list of the provider), paste your API key, optionally a custom Base URL (for proxies or OpenAI-compatible endpoints).
  3. Click Add in the dialog, then Deploy (top-right) to persist. The key is stored encrypted in flows_cred.json server-side.
  4. Repeat + to add as many providers as you like โ€” multiple OpenAI keys, mix OpenAI + Anthropic, different models. Switch between them from the dropdown at any time, even mid-conversation.
Conversations are provider-agnostic: the chosen provider is a per-message attribute, not a per-chat setting. You can start with GPT-X, continue with Claude, switch back โ€” the whole history stays.
Sidebar anatomy
  • Toolbar (top): + (new chat) ยท conversations dropdown ยท ๐Ÿ—‘ (delete current chat) ยท provider dropdown ยท + (add provider) ยท โš™ (edit selected provider).
  • Messages area โ€” scrollable, user messages right-aligned, assistant left-aligned, code blocks with Copy / Preview / Apply buttons.
  • Context row (just above the textarea): ๐Ÿ“ active tab chip (click to add more tabs to the context via a compact multi-select) ยท ๐Ÿ“Ž (attach files) ยท previews of pending attachments.
  • Textarea โ€” full width, Ctrl/โŒ˜+Enter to send.
  • Send button โ€” full-width under the textarea.
Day-to-day flow
  1. New chat โ€” click + (leftmost button). Conversations are listed in the dropdown โ€” reopen any time, click ๐Ÿ—‘ to delete (removes attachments too).
  2. Pick a provider from the dropdown. Click + / โš™ next to it to add/edit providers without leaving the sidebar.
  3. Tab context โ€” the active canvas tab is always sent. Click the compact chip (๐Ÿ“ active tab) to open a multi-select and add other tabs to the context for this message (e.g. "look at Flow 2 and Flow 3").
  4. Attach files โ€” click ๐Ÿ“Ž. Supported: images (vision), PDFs (Anthropic has native support), text / JSON / YAML / CSV / logs. Click on a chip in the message to open the viewer (lightbox / text pane / PDF embed). Attachments persist with the conversation.
  5. Send โ€” Ctrl/โŒ˜+Enter or the paper-plane button. Responses stream in real time.
What the AI sees
Every message sends, as system context, a sanitized snapshot of:
  • the active tab + any extra tabs you ticked in the multi-select,
  • the full catalog of registered node types, grouped by module, with the core modules flagged โ€” so the AI knows exactly what's usable in this installation (and what isn't).
The sanitizer scrubs anything that looks like a secret value (key names are kept so the model understands the structure). See Security below.
Apply-able code blocks
When the AI proposes changes, it wraps them in fenced code blocks using one of these language labels:
Language label Action when you click Apply
```json:flow:<tabId> Import JSON nodes into that tab
```json:flow:new Create a brand-new tab and import the nodes there
```json:node:<nodeId> Patch the specified node's fields
```json:subflow:<id|new> Create/update a subflow
```json:delete Delete an array of node / tab IDs (cleans inbound wires automatically)
```json:connect Add wires: [{ "from":"<src>", "port":0, "to":"<dst>" }] (non-destructive)
```json:disconnect Remove specific wires (same shape as connect)
any other (json, text, js) Copy only โ€” no automatic apply
Every block has its own Copy / Preview / Apply buttons:
  • Copy โ€” copies the raw content to the clipboard.
  • Preview โ€” shows a plain-English summary of what the Apply would do (how many nodes, in which tab, which fields patched, which wires added/removed). Confirm or cancel.
  • Apply โ€” performs the change against the editor in memory. Added to the undo history, so Ctrl+Z / Ctrl+Y work as usual. Changes are not deployed automatically โ€” hit the Deploy button when you're ready.
Prompting tips
  • Be explicit about scope when you want changes in a specific tab: "add a http-in on Flow 2 and wire it to the existing JSON parser".
  • If an apply block references a node ID that no longer exists (e.g. you deleted it), the apply will report "node not found" in a toast โ€” harmless.
  • Ask the AI to only produce a json:connect block when you just want to wire two nodes without recreating them from scratch.
  • Ctrl+Z undoes the entire apply as a single operation.
Example prompts
  • "Add an inject node that fires every 5s and pipe its payload to a debug node." โ†’ json:flow:<tabId>.
  • "Connect the existing mqtt-in a1b2c3 to the function node d4e5f6." โ†’ json:connect.
  • "Disable the debug node xy12z3 and rename it to 'legacy'." โ†’ json:node:xy12z3.
  • "Remove all the http nodes from this tab." โ†’ json:delete.
  • "Summarize what this flow does." โ†’ plain markdown, no Apply buttons.
Security
Before sending flow JSON to the provider, the sanitizer:
  • removes every ai-provider-config node entirely,
  • replaces values under keys matching password, passwd, pwd, token, secret, apiKey, auth, authorization, bearer, privateKey, credentials with [REDACTED] (key names are kept so the model understands the structure),
  • leaves ${env.FOO} / ${settings.BAR} references intact โ€” those are just names, the actual secrets live in settings.js / process.env and are never present in the flow JSON.
On Apply, any [REDACTED] value in the AI's response is dropped before the change hits the editor โ€” so the pre-existing real secret in that field is preserved, never overwritten with the placeholder string. A notification lists which paths were kept.
Attachments are stored at <userDir>/ai-flow-builder/attachments/<conversationId>/. Deleting a conversation deletes its attachment folder too.
Development
git clone https://github.com/Siphion/node-red-contrib-ai-flow-builder
cd node-red-contrib-ai-flow-builder
npm install
npm test                        # mocha unit tests (sanitizer + storage)
cd docker && docker compose up  # Node-RED 4.1 on http://localhost:1880
docker/docker-compose.yml mounts this repo as a linked module inside the Node-RED container at /data/node_modules/node-red-contrib-ai-flow-builder. Restart the container after editing server-side code; for browser-side code just hard-reload the editor.
Project layout
nodes/                 Node-RED node definitions (config node + sidebar bootstrap)
lib/                   Backend
  providers/           OpenAI + Anthropic streaming wrappers
  storage.js           Atomic JSON storage under userDir
  sanitizer.js         Flow JSON credential/env stripper
  context-builder.js   System prompt composer
public/                Frontend
  ai-chat.js           Sidebar logic
  message-renderer.js  Markdown โ†’ HTML with Copy/Apply blocks
  apply-handlers.js    Dispatch on language labels โ†’ RED.nodes.import / patch / new tab
  ai-chat.css          Styling
test/                  Mocha unit tests
docker/                Local dev compose
Troubleshooting
  • Dropdown says "no providers" โ€” click +, fill the form, hit Add and Deploy. Until deploy, the provider exists in the editor but the backend can't read the (encrypted) API key.
  • "Remember to Deploy" toast โ€” shown when you modified a provider but did not deploy yet. The backend needs a deploy to read the new credentials.
  • Apply says "node not found" โ€” the AI referenced an ID that no longer exists. Just ask the AI to use the current IDs (which are visible in its context).
  • Unexpected [REDACTED] in an apply โ€” means the sanitizer stripped that field on the way out, and the model echoed the placeholder back. The apply step drops those automatically so your existing secret is preserved. To unblock, fill the real value manually in the node editor, or reference it via ${env.MY_VAR}.
  • File upload fails โ€” max size per attachment is 25 MB, and you must have an active conversation.
Roadmap
  • Syntax highlighting (ace) inside code blocks
  • Tool-call / function-call mode (structured outputs)
  • Per-conversation provider lock (to prevent accidental switches, track costs)
  • Inline diff preview for existing nodes
  • i18n
  • Publish on flows.nodered.org
MIT ยฉ Siphion
Version: 0.1.2
Updated 7 months, 1 week ago
Rating: 3.0 2
  • ai-provider-config
  • ai
  • openai
  • anthropic
  • claude
  • chat
  • assistant
  • flow-builder
