node-red-contrib-afya-panic-button 0.1.0
Node-RED panic button: reports "panic" (or any value) when it receives Y messages within X seconds – e.g. one remote button pressed 5× in 10 s.
npm install node-red-contrib-afya-panic-button
npm license: MIT
Node-RED panic button: reports panic (or any value you set) when it receives Y messages within X seconds. No extra plugins needed.
English · Polski
English
Best used with a remote (Hue / Tradfri): press one button e.g. 5× within 10 s to arm the alarm, lock the flat and switch all lights off.
Requires Node-RED ≥ 3.0 and Node.js ≥ 18. The node appears in the AFYA palette group as panic button.
Field Description
Clicks How many messages trigger panic (Y).
Within Time window in seconds (X), counted from the first click of a series.
Panic / No panic Values sent in msg.payload.state.
Variable Context variable with the click counter – global (readable from any flow) or flow. Every new node gets a unique name; give several nodes the same name only if they should share one counter.
Name Optional label.
Output
{ "state": "dont_panic", "count": 3, "timestamp": 1764057600000 }
{ "state": "panic", "count": 5, "timestamp": 1764057604000 }
Other message properties are passed through – route the panic with a switch node on msg.payload.state.
Upgrading to 0.1.0
The default variable name used to be the same for all nodes added in one editor session – now every node gets its own. Nodes created with older versions keep using flow context until you change it. See change.log.
Polski
Zgłasza panic (lub dowolną ustaloną wartość), gdy w ciągu X sekund przyjdzie Y wiadomości. Najlepiej z pilotem (Hue / Tradfri): 5× ten sam przycisk w 10 s uzbraja alarm, zamyka mieszkanie i gasi światła.
Instalacja
Wymaga Node-RED ≥ 3.0 i Node.js ≥ 18. Węzeł panic button jest w grupie palety AFYA.
Konfiguracja
  • Clicks – ile wiadomości (Y), Within – w ilu sekundach (X),
  • Panic / No panic – wartości w msg.payload.state,
  • Variable – zmienna global lub flow z licznikiem; każdy nowy węzeł dostaje unikalną nazwę (tę samą nazwę daj kilku węzłom tylko wtedy, gdy mają dzielić jeden licznik).
Węzły z wcześniejszych wersji używają nadal flow, dopóki nie zmienisz tego w formularzu.
Marcin Chuć · MIT
Version: 0.1.0
Updated 2 days ago
24 in the last week
  • afya-panic-button
  • afya
  • panic
  • button
  • remote
  • multi-click
  • alarm
  • global
  • context
