node-red-contrib-afya-lullaby 0.2.0
Node-RED dimmer helper: changes a value from X to Y in Z seconds – dim the light to fall asleep or brighten it for a slow wake-up.
Node-RED dimmer helper: changes a value from X to Y in Z seconds. Made for my children, who like falling asleep with the light on – it dims the light slowly. It also works the other way round, as a slow wake-up light.
English
The node does not control a lamp itself – it calculates the value. Use msg.payload.value for your light.
npm install node-red-contrib-afya-lullaby
Requires Node-RED ≥ 3.0 and Node.js ≥ 18. The node appears in the AFYA palette group as lullaby.
| Field | Description |
| Start value | Value at the beginning (e.g. 100). |
| Stop value | Value at the end (e.g. 0). Start > stop: dimming; start < stop: brightening. |
| Step | Change per step (integer > 0). |
| Time | Total time in seconds (20 min = 1200). |
| Variable | Context variable with the current state – global (readable from any flow) or flow. |
| Name | Optional label. |
Input
- any message – start (ignored while running),
msg.payload = "stop"or"kill"– stop at the current value.
Start from the current value (msg.payload)
Turn on Start from the number in msg.payload and send the current value as a number, e.g. the brightness of the lamp – the change starts from there instead of the configured start value:
- above the stop value – dimming, below – brightening; equal – the node sends
endat once, - text, objects and timestamps (a default inject) keep the configured start value,
- Time from there: always the time above, or same speed – with 100 → 0 in 20 min, 50 → 0 takes 10 min.
Handy e.g. for a home theatre: dim from the brightness the lights have when the film starts. If the
brightness comes in another property (e.g. msg.payload.brightness), move it to msg.payload with a
change node first.
Output
{ "value": 57, "state": "counting", "direction": "down", "timestamp": 1764057600000 }
state: counting while running, end with the final (stop) value.
The context variable additionally holds startValue, stopValue, startTime, stopTime and can have
state = killed or stopped (redeploy).
Example flow: https://flows.nodered.org/flow/ce2fe16f73fc82e2760eaaadf28991b9
Upgrading to 0.1.0
The node was registered under a wrong key in package.json (afya-panic-button) – fixed, both packages can now
be installed side by side. Older nodes get the context variable when you open and save them.
See change.log.
Polski
Zmienia wartość od X do Y w czasie Z sekund. Stworzony dla moich dzieci, które lubią zasypiać przy zapalonym świetle – powoli je wygasza. Działa też w drugą stronę, jako budzenie światłem.
Węzeł nie steruje lampą – tylko liczy wartość. Użyj msg.payload.value.
Instalacja
Wymaga Node-RED ≥ 3.0 i Node.js ≥ 18. Węzeł lullaby jest w grupie palety AFYA.
Użycie
- Start value / Stop value – od czego do czego (start > stop: gaszenie, start < stop: rozjaśnianie),
- Step – zmiana na krok, Time – czas w sekundach (20 min = 1200),
- Variable – zmienna global lub flow z bieżącym stanem (dostępna z innych flow),
- dowolna wiadomość uruchamia,
msg.payload = "stop"lub"kill"przerywa, - Start from the number in msg.payload – liczba w
msg.payload(np. obecna jasność lampy) staje się wartością startową; kierunek wynika z niej, a Time from there decyduje, czy czas jest zawsze ten sam, czy prędkość (krótszy zakres – krócej). Tekst, obiekt i znacznik czasu z inject nie zmieniają startu.
Na wyjściu: { value, state, direction, timestamp }, state: counting lub end.
Marcin Chuć · MIT
