node-red-contrib-afya-librus 1.2.0
Node-RED node for the Polish school register Librus Synergia: new grades and teacher notes, what they are for, ready-made SMS text. No Home Assistant needed.
Node-RED node for the Polish school register Librus Synergia: it reads the grades (optionally also teacher notes) and tells you what is new and what it is for – category, teacher's comment, weight, average and all grades of the subject. The result is ready for an SMS gateway. No Home Assistant, no Python.
English · Polski · Example flow / przykładowy flow: Librus → MQTT / SMS
English
[inject every 1 h] → [librus grades] → [switch: payload.tekst not empty] → [SMS sender]
Example SMS (the text is Polish, as it goes to Polish parents):
Librus Kowalski Jaś: 4[1](2) z Matematyka (Kartkówka) | oceny: 5(3), 3-(2), +, 4[1](2)
Librus Kowalski Jaś: uwaga negatywna – Brak zadania domowego (Testowa Anna)
Grades are written as in the register: grade(weight). An improved grade looks like new[old],
e.g. 4[1](2) = 4 after improving 1, weight 2.
Requires Node.js ≥ 18.17 and Node-RED ≥ 3.
npm install node-red-contrib-afya-librus
# or straight from GitHub:
npm install github:mchuc/node-red-contrib-afya-librus
Restart Node-RED. The node librus grades appears in the AFYA palette group.
| Field | Description |
| Login, Password | Parent or student account. Stored as Node-RED credentials, never exported with the flow. |
| New grade | SMS line template for a new grade. Default: Librus %uczen%: %zapis% z %przedmiot% (%kategoria%) %komentarz% |
| Append all grades of the subject | Adds | oceny: 5(3), 3-(2), 4[1](2) (current semester of the subject) to each grade line. |
| Without Polish letters | Replaces ą→a, ł→l …, so one SMS holds 160 instead of 70 characters. |
| Also read teacher notes | Reads the “Uwagi” page and reports new notes. |
| New note | SMS line template for a new note. Default: Librus %uczen%: uwaga %rodzaj% – %tresc% (%nauczyciel%) |
| Variable | Optional: the last msg.payload is also stored in a global (readable from any flow) or flow context variable, e.g. global.get("librus_john"). |
| Show a web page with the grades | Turns on the grades page (see below). |
| Page path | Address of the page, e.g. librus/john → http://<node-red>:1880/librus/john. One path per child. |
| Page title | Shown in the page header and the browser tab, e.g. John's grades. Empty = student's name. |
| Page password | Password for the page (login form, 30-day session). Stored as credentials. |
| Access token | Optional. The link …/librus/john?token=… opens the page without logging in – for a smart mirror or a wall tablet. Generate creates a random token, Copy copies the whole link. |
Grade placeholders: %zapis% %ocena% %przedmiot% %kategoria% %komentarz% %waga% %data%
%nauczyciel% %srednia% %tablica% %semestr% %uczen%.
Note placeholders: %tresc% %rodzaj% %kategoria% %nauczyciel% %data% %uczen%.
Every incoming message starts one check. Ready flows: Menu → Import → Examples → node-red-contrib-afya-librus:
- librus-mqtt – schedule (7:00–15:00 every 45 min, 15:00–21:00 hourly, no checks at night) and MQTT topics
librus/dane(retained, full result),librus/sms/jsonandlibrus/sms/tekst(only when something is new), - librus-sms – the simplest variant (inject every 1 h → node → debug).
The librus-mqtt flow is also in the Node-RED library: Librus Synergia: new school grades & notes → MQTT / SMS.
Pass only messages with a non-empty msg.payload.tekst to the SMS gateway (e.g. a switch node, rule
“is not empty”), otherwise an SMS would go out after every check. Set TZ=Europe/Warsaw for the schedule.
Grades page
Each node can serve its own web page with the grades – one node, path and password per child
(e.g. /librus/john and /librus/anna):
- student and class at the top, tabs Term 1 / Term 2 / Whole year (the current term opens first),
- subjects in alphabetical order, the weighted average right after the subject name,
- the grades in order, coloured by value, with the weight as a small number – hover or tap a grade to see the date, category, weight, teacher and comment,
- dashed frame – the grade does not count to the average; solid frame – predicted / term / final grade,
- works on a phone and in dark mode, refreshes itself every 15 minutes.
The average is taken from Librus (columns Śr.I / Śr.II / Śr.R, so the school's own weights and
settings apply). If the school hides the averages, it is calculated from the Librus weights (+ = +0.5,
- = −0.25, only grades with “Licz do średniej: tak”) and marked with *.
Access – set a password, a token, or both (without either the page stays off):
- password – a login form, then a session cookie (
HttpOnly,SameSite=Strict) for 30 days; changing the password logs everyone out, - token – the link
http://<node-red>:1880/librus/john?token=…shows the page straight away, without logging in, e.g. on a smart mirror or a tablet on the wall. Anyone with the link sees the grades, so keep it like a password; to revoke it, generate a new token and deploy. The link ends up in the browser history and in proxy logs – use a long, generated token.
10 wrong passwords or tokens in 15 minutes block the address for a while.
The page is served by Node-RED itself (under httpNodeRoot), so it is reachable wherever Node-RED is – put it
behind HTTPS / VPN when you open it to the internet. The last result is stored in
~/.node-red/afya-librus/<node-id>.json, so the page works right after a restart.
Output (msg.payload)
Field names are Polish (unchanged since 1.0):
| Field | Meaning |
ok |
true – read successfully; on error { ok: false, czas, blad } (blad = error text) |
nowe |
grades that were not there at the previous check (with subject average srednia and tablica) |
tekst |
ready SMS text, one line per new grade / note; empty when nothing is new |
oceny |
all grades: przedmiot (subject), ocena (grade), zapis (as in the register), przed (before improvement), wartosc (numeric value), kategoria, komentarz, data, nauczyciel (teacher), waga (weight), liczy (counts to average), semestr, typ (biezaca regular / koncowa predicted, semester or final), zastapiona (old, improved grade), link, id |
srednie |
weighted averages per term and year: { "Matematyka": { "1": 4.07, "2": 4.5, "R": 4.13 } } – from Librus (Śr.I / Śr.II / Śr.R) or calculated from the Librus weights where the school hides them |
srednieLibrus |
only the averages Librus itself shows |
tablica |
all regular grades of a subject in one string, per semester |
uwagi, noweUwagi |
teacher notes (only with Also read teacher notes): tresc, data, nauczyciel, rodzaj, kategoria, id |
uczen, klasa |
student and class |
pierwszyOdczyt |
true on the very first check – grades are only remembered |
czas |
time of the check (ISO) |
SMS test
Send msg.test = true. When nothing is new, the latest grade (and note) is reported as new, so you can check
the whole SMS path at once. The example flows have a separate inject for it.
How new grades are detected
Seen grades and notes are saved in ~/.node-red/afya-librus/<node-id>.json, so a restart does not cause
duplicates. The first check only remembers the state (pierwszyOdczyt: true) – no SMS with the whole year of
grades. Turning on notes later works the same way. A grade is recognised by its Librus number and value, so a
changed value is reported too.
Limitations
- Descriptive grades in the new layout (classes 1–3) are not read.
- Accounts with two-factor login confirmation are not supported.
- The node reads the Synergia web pages – when Librus changes the login or the page layout, it may stop
working; you then get
ok: falsewith a description.
Tests
npm install
npm test
Tests do not connect to Librus – they use a fake server and synthetic pages with fictional data.
Credits
Inspired by LibrusSynergiaHA for Home Assistant (LukMaverick). This node works differently: it connects to Synergia itself, runs in Node-RED and is written from scratch in JavaScript. Unofficial project, not affiliated with Librus.
Polski
Węzeł Node-RED, który loguje się do dziennika Librus Synergia, czyta oceny (opcjonalnie też uwagi) i mówi, co jest nowego i za co: kategoria, komentarz nauczyciela, waga, średnia i wszystkie oceny z przedmiotu. Wynik od razu nadaje się do bramki SMS. Nie potrzebuje Home Assistanta ani Pythona.
[inject co 1 h] → [librus grades] → [switch: payload.tekst niepusty] → [SMS sender]
Przykładowy SMS:
Oceny są zapisane jak w dzienniku: ocena(waga). Poprawiona ocena ma postać po[przed],
np. 4[1](2) oznacza 4 po poprawie z 1, z wagą 2.
Instalacja
Wymagania: Node.js ≥ 18.17, Node-RED ≥ 3.
npm install /ścieżka/do/node-red-contrib-afya-librus
# albo prosto z GitHuba:
Potem zrestartuj Node-RED. Węzeł librus grades pojawi się w palecie, w grupie AFYA.
Konfiguracja węzła
| Pole | Opis |
| Login, Password | Konto rodzica lub ucznia w Librusie. Zapisywane jako credentials Node-RED, więc nie trafiają do eksportu flow. |
| New grade | Szablon linii SMS o nowej ocenie. Domyślnie: Librus %uczen%: %zapis% z %przedmiot% (%kategoria%) %komentarz% |
| Without Polish letters | Zamienia ą→a, ł→l itd., więc SMS mieści 160 znaków zamiast 70. |
| Append all grades of the subject | Do każdej linii o ocenie dopisuje | oceny: 5(3), 3-(2), 4[1](2) (bieżący semestr tego przedmiotu). |
| Also read teacher notes | Czyta stronę „Uwagi” i zgłasza nowe uwagi. |
| New note | Szablon linii SMS o nowej uwadze. Domyślnie: Librus %uczen%: uwaga %rodzaj% – %tresc% (%nauczyciel%) |
| Variable | Opcjonalnie: ostatni msg.payload trafia też do zmiennej global (dostępna z każdego flow) lub flow, np. global.get("librus_jas"). |
| Show a web page with the grades | Włącza stronę z ocenami (opis niżej). |
| Page path | Adres strony, np. librus/jas → http://<node-red>:1880/librus/jas. Każde dziecko – osobna ścieżka. |
| Page title | Tytuł w nagłówku strony i na karcie przeglądarki, np. Oceny Jasia. Puste = imię i nazwisko ucznia. |
| Page password | Hasło do strony (formularz logowania, sesja na 30 dni). Zapisywane jako credentials. |
| Access token | Opcjonalnie. Link …/librus/jas?token=… otwiera stronę bez logowania – na lustro albo tablet na ścianie. Generate tworzy losowy token, Copy kopiuje cały link. |
Pola w szablonie oceny: %zapis% %ocena% %przedmiot% %kategoria% %komentarz% %waga%
%data% %nauczyciel% %srednia% %tablica% %semestr% %uczen%.
Pola w szablonie uwagi: %tresc% %rodzaj% %kategoria% %nauczyciel% %data% %uczen%.
Użycie
Każda wiadomość na wejściu uruchamia jedno sprawdzenie. Gotowe flow znajdziesz w Menu → Import → Przykłady → node-red-contrib-afya-librus:
- librus-mqtt: pełny schemat z harmonogramem i MQTT (opis niżej),
- librus-sms: najprostszy wariant (inject co 1 h → węzeł → debug).
Flow librus-mqtt jest też w bibliotece Node-RED: Librus Synergia: new school grades & notes → MQTT / SMS.
Do bramki SMS przepuszczaj tylko wiadomości z niepustym msg.payload.tekst, np. węzłem
switch z regułą „is not empty”. Inaczej SMS wychodziłby przy każdym sprawdzeniu.
Przykład „librus-mqtt”: harmonogram i MQTT
zegar 1: co 45 min ─► [tylko 7:00–15:00] ─┐
zegar 2: co 1 h, 15–21 ───────────────────┼─► [Librus – oceny] ─► librus/dane (retain)
test SMS (msg.test) ──────────────────────┘ │
└─► [coś nowego?] ─► [SMS jako JSON] ─► librus/sms/json
└─► [SMS jako tekst] ─► librus/sms/tekst
- 7:00–15:00: sprawdzenie co 45 minut. Interwał 45 min jest ustawiony w zwykłym inject.
Filtr godzin to krótka funkcja, w której godziny
OD/DOzmienisz na górze kodu. - 15:00–21:00: sprawdzenie co godzinę (ostatnie o 21:00).
- 22:00–7:00: brak sprawdzeń.
- Godziny są liczone wg strefy czasowej serwera Node-RED, więc ustaw
TZ=Europe/Warsaw.
Tematy MQTT:
| Temat | Kiedy | Treść |
librus/dane (retain) |
po każdym sprawdzeniu | cały msg.payload (ok, nowe, oceny, tablica, uwagi…) albo ok:false z blad |
librus/sms/json |
tylko gdy coś nowego | wariant A: obiekt JSON dla bramki SMS |
librus/sms/tekst |
tylko gdy coś nowego | wariant B: zwykły tekst SMS |
Wariant A ma postać:
{ "do": "48600000000", "tresc": "Librus Kowalski Jaś: 6(2) z Język polski (Wypracowanie)", "od": "DZIENNIK", "flash": false }
do to numer odbiorcy; kilka numerów oddziel przecinkami. od to nazwa nadawcy. Oba ustawisz
w węźle SMS jako JSON. Zostaw wariant, którego używa Twoja bramka SMS, a drugi usuń.
Po imporcie ustaw jeszcze login i hasło Librusa oraz adres brokera, a potem kliknij test SMS.
Strona z ocenami
Każdy węzeł może pokazywać własną stronę z ocenami – osobny węzeł, ścieżka i hasło dla każdego dziecka
(np. /librus/jas i /librus/ola):
- na górze uczeń i klasa, zakładki Okres 1 / Okres 2 / Cały rok (otwiera się bieżący okres),
- przedmioty alfabetycznie, średnia ważona zaraz po nazwie przedmiotu,
- kolejne oceny w kolorach wg wartości, waga jako mała liczba – po najechaniu albo dotknięciu widać datę, kategorię, wagę, nauczyciela i komentarz,
- ramka przerywana – ocena nie liczy się do średniej; pełna ramka – ocena przewidywana, śródroczna lub roczna,
- działa na telefonie i w trybie ciemnym, sama odświeża się co 15 minut.
Średnia jest brana z Librusa (kolumny Śr.I / Śr.II / Śr.R, więc obowiązują wagi i ustawienia szkoły).
Gdy szkoła ukrywa średnie, jest wyliczana z wag Librusa (+ = +0,5, - = −0,25, tylko oceny z „Licz do
średniej: tak”) i oznaczona *.
Dostęp – ustaw hasło, token albo oba (bez żadnego strona jest wyłączona):
- hasło – formularz logowania, potem ciasteczko sesji (
HttpOnly,SameSite=Strict) na 30 dni; zmiana hasła wylogowuje wszystkich, - token – link
http://<node-red>:1880/librus/jas?token=…pokazuje stronę od razu, bez logowania, np. na lustrze albo tablecie na ścianie. Kto ma link, widzi oceny – traktuj go jak hasło; żeby go unieważnić, wygeneruj nowy token i wdróż. Link zostaje w historii przeglądarki i w logach pośredników – używaj długiego, wygenerowanego tokenu.
10 błędnych haseł albo tokenów w 15 minut blokuje adres na chwilę. Stronę
serwuje sam Node-RED, więc jest dostępna tam, gdzie Node-RED – wystawiając ją do internetu, użyj HTTPS / VPN.
Ostatni wynik leży w ~/.node-red/afya-librus/<id-węzła>.json, więc strona działa zaraz po restarcie.
Wyjście (msg.payload)
"ok": true,
"czas": "2026-11-25T07:00:03.120Z",
"uczen": "Kowalski Jaś",
"klasa": "7 b",
"nowe": [
"przedmiot": "Matematyka",
"ocena": "4",
"zapis": "4[1](2)",
"przed": "1",
"wartosc": 4,
"kategoria": "Kartkówka",
"komentarz": "",
"data": "2026-11-17",
"nauczyciel": "Testowa Anna",
"waga": 2,
"liczy": true,
"semestr": 1,
"typ": "biezaca",
"zastapiona": false,
"link": "https://synergia.librus.pl/przegladaj_oceny/szczegoly/5005",
"id": "5005:4",
"srednia": 4.07,
"tablica": "5(3), 3-(2), +, 4[1](2)"
"tekst": "Librus Kowalski Jaś: 4[1](2) z Matematyka (Kartkówka) | oceny: 5(3), 3-(2), +, 4[1](2)",
"pierwszyOdczyt": false,
"oceny": [ "… wszystkie oceny w tym samym formacie …" ],
"srednie": { "Matematyka": { "1": 4.07, "2": 4.5 } },
"tablica": { "Matematyka": { "1": "5(3), 3-(2), +, 4[1](2)", "2": "4+(1)" } },
"noweUwagi": [],
"uwagi": [
"id": "3f1c9a0b7d2e",
"tresc": "Pomoc przy organizacji apelu",
"data": "2026-11-05",
"nauczyciel": "Przykładowy Jan",
"rodzaj": "pozytywna",
"kategoria": "Aktywność"
ok:true, gdy odczyt się udał. Przy błędzie dostajesz{ "ok": false, "czas": "…", "blad": "opis" }.nowe: oceny, których nie było przy poprzednim sprawdzeniu.tekst: gotowy SMS, jedna linia na każdą nową ocenę i uwagę. Pusty, gdy nic nowego.zapis: ocena jak w dzienniku, np.5(3),4[1](2)albo+.przed: ocena sprzed poprawy.zastapiona: trueoznacza starą ocenę, którą uczeń poprawił. Taka ocena nie trafia donoweani dotablica, widać ją tylko w nawiasie.typ:biezaca(zwykła ocena) albokoncowa(przewidywana, śródroczna lub roczna, szczegóły wkategoria).srednie: średnie ważone dla okresów i roku (1,2,R) – z Librusa (Śr.I / Śr.II / Śr.R), a gdy szkoła je ukrywa, wyliczone z wag Librusa.srednieLibrus– tylko te, które pokazuje sam Librus.tablica: wszystkie oceny bieżące przedmiotu w jednym napisie, osobno dla każdego semestru.uwagi,noweUwagi: pojawiają się tylko wtedy, gdy włączona jest opcja „Also read teacher notes”.
Test SMS
Wyślij do węzła msg.test = true. Jeśli nie ma nowości, najnowsza ocena (i uwaga, jeśli są
włączone) zostanie podana jako nowa, więc od razu zobaczysz, czy SMS dochodzi. W przykładowym
flow jest do tego osobny inject.
Jak wykrywane są nowości
Lista już widzianych ocen i uwag leży w pliku ~/.node-red/afya-librus/<id-węzła>.json, więc
restart Node-RED nie powoduje duplikatów. Pierwsze uruchomienie tylko zapamiętuje stan
(pierwszyOdczyt: true), żeby nie wysłać SMS-a z całym rokiem ocen. Tak samo działa pierwsze
włączenie opcji uwag. Ocena jest rozpoznawana po numerze w Librusie i wartości, więc zmiana
wartości przez nauczyciela też zostanie zgłoszona.
Ograniczenia
- Oceny opisowe w nowym układzie Librusa (klasy 1–3) nie są odczytywane.
- Konta z dodatkowym potwierdzeniem logowania (2FA) nie są obsługiwane.
- Węzeł czyta stronę WWW Synergii. Gdy Librus zmieni logowanie albo wygląd strony, może przestać
działać. Dostaniesz wtedy
ok: falsez opisem błędu.
Testy
npm install
npm test
Testy nie łączą się z Librusem. Używają atrapy serwera i syntetycznych stron z fikcyjnymi danymi.
Skąd pomysł
Inspiracją była integracja LibrusSynergiaHA dla Home Assistanta (LukMaverick). Ten węzeł działa na innej zasadzie: sam łączy się z Synergią, działa w Node-RED i jest napisany od zera w JavaScripcie.
Projekt nieoficjalny, niezwiązany z firmą Librus.
Marcin Chuć · MIT
