node-red-contrib-afya-globals 1.1.0
Node-RED node that sets typed global / flow context variables (string, integer, float, boolean, JSON) on deploy and from msg.payload.
npm install node-red-contrib-afya-globals
npm license: MIT
Node-RED node that sets typed global or flow context variables – once on deploy and then with every incoming message.
English · Polski
English
What it does
  • On deploy it sets global.<name> (or flow.<name>) to the configured value, converted to the chosen type.
  • Every incoming msg.payload overwrites the variable – plain values are converted to that type (e.g. "21,5" → 21.5 for float), objects and arrays are stored as they are.
  • Optionally sends the value to the output right after deploy – handy for start-up initialisation.
Requires Node-RED ≥ 3.0 and Node.js ≥ 18. The node appears in the AFYA palette group as set variable.
Field Description
Variable Name and scope (global / flow). If more context stores are configured in settings.js (e.g. a persistent file store), you can pick the store here too.
Value Initial value with its type: string, integer, float, boolean, JSON or none (nothing is set on deploy, the node waits for msg.payload).
Send the value after deploy Emits msg.payload = value (and msg.topic = variable name) 100 ms after start.
Name Optional label; when empty the node shows scope.name = value.
Type conversion:
Type Conversion
string String(value); objects as JSON text
integer Math.floor(Number(value)), comma or dot as decimal separator
float Number(value), comma or dot as decimal separator
boolean true/false, 1/0, +/-
JSON JSON.parse(text); objects are kept
none value stored as it comes
Input / output
  • Input msg.payload – new value.
  • Output – the same message with msg.payload = stored (converted) value.
  • Conversion errors (e.g. "abc" for float) leave the variable unchanged, turn the status red and are passed to a Catch node.
Reading the variable
// function node
const pi = global.get("pi");
…or in change, switch and inject nodes via global.pi.
Example
Menu → Import → Examples → node-red-contrib-afya-globals → AFYA Globals Examples
What's new in 1.1.0
Native global/flow picker with context stores, value field with a type picker (JSON editor included), fixed handling of incoming messages, modern edit dialog. Existing flows keep working without changes. See change.log.
Polski
Co robi
  • Po wdrożeniu (deploy) ustawia global.<nazwa> lub flow.<nazwa> na podaną wartość, zamienioną na wybrany typ.
  • Każde msg.payload nadpisuje zmienną – wartości proste są zamieniane na ten typ (np. "21,5" → 21.5 dla float), obiekty i tablice zapisywane bez zmian.
  • Opcjonalnie wysyła wartość na wyjście zaraz po starcie – do inicjalizacji po restarcie.
Instalacja
Wymaga Node-RED ≥ 3.0 i Node.js ≥ 18. Węzeł set variable jest w grupie palety AFYA.
Konfiguracja
Pole Opis
Variable Nazwa i zakres (global / flow), opcjonalnie magazyn kontekstu (np. trwały file).
Value Wartość początkowa z typem: string, integer, float, boolean, JSON lub none (nic nie jest ustawiane, węzeł czeka na msg.payload).
Send the value after deploy Wysyła msg.payload = wartość (i msg.topic = nazwa zmiennej) 100 ms po starcie.
Name Opcjonalna nazwa; gdy pusta, węzeł pokazuje zakres.nazwa = wartość.
Błąd zamiany (np. "abc" dla float) nie zmienia zmiennej, daje czerwony status i trafia do węzła Catch. Zmienną odczytasz w dowolnym flow: global.get("nazwa").
Nowości w 1.1.0
Wybór global/flow z magazynami kontekstu, jedno pole wartości z typem (z edytorem JSON), poprawiona obsługa wiadomości wejściowych, nowoczesny formularz. Istniejące flow działają bez zmian.
Marcin Chuć · ORCID 0000-0002-8430-9763 · MIT
Version: 1.1.0
Updated 2 days ago
9 in the last week
  • AFYA-globals
  • afya
  • global
  • flow
  • context
  • variable
  • typed
  • scope
  • inject
  • at start
  • default values
  • JSON
