node-red-contrib-afya-carousel-switch 0.1.0
Node-RED carousel switch: every message steps the value 0, 1, 2 … max, 0 … (forward or backward) – for scenes switched with one button.
Node-RED carousel switch: every message steps the value 0 → 1 → 2 → … → max → 0 … – made for scenes switched with one button.
English
npm install node-red-contrib-afya-carousel-switch
Requires Node-RED ≥ 3.0 and Node.js ≥ 18. The node appears in the AFYA palette group as carousel switch.
| Field | Description |
| Labels | Language of the descriptions in the edit dialog: system language (Polish for a Polish system, English for all others), English or Polski. Only the descriptions change – fields and values stay the same. |
| Maximum value | Highest position; the carousel goes 0 … max. |
| Variable | Context variable with the current position – global (readable from any flow) or flow, optionally in a chosen context store. New nodes get a unique name. |
| Name | Optional label. |
Input
Any message makes one step. Optional commands in msg.payload (value "yes" or true):
| Command | Effect |
msg.payload.rev |
step backwards: max → … → 1 → 0 → max |
msg.payload.reset |
start again – next value is 0 (or max backwards) |
msg.payload.noop |
do nothing and send nothing – use with reset to only reset |
Output
{ "value": 1, "maxValue": 2, "direction": 1, "timestamp": 1764057600000 }
direction: 1 forward, -1 backward. Other message properties (e.g. msg.topic) are passed through.
Reading the position elsewhere
const scene = global.get("AFYA_xxxxx"); // the name shown in the node
Upgrading to 0.1.0
Nodes created with older versions keep using flow context until you open them and choose global. See change.log.
Polski
Każda wiadomość zwiększa wartość o 1: 0 → 1 → 2 → … → max → 0 … – do scen przełączanych jednym przyciskiem.
Instalacja
Wymaga Node-RED ≥ 3.0 i Node.js ≥ 18. Węzeł carousel switch jest w grupie palety AFYA.
Konfiguracja
| Pole | Opis |
| Labels (Etykiety) | Język opisów w oknie konfiguracji: język systemu (polski dla polskiego systemu, angielski dla każdego innego), English albo Polski. Zmieniają się tylko opisy – pola i wartości zostają takie same. |
| Maximum value | Najwyższa pozycja; karuzela chodzi 0 … max. |
| Variable | Zmienna z bieżącą pozycją – global (dostępna z każdego flow) lub flow, opcjonalnie w wybranym magazynie kontekstu. Nowy węzeł dostaje unikalną nazwę. |
Komendy w msg.payload (wartość "yes" lub true)
rev– krok do tyłu,reset– od początku (następna wartość0, w tyłmax),noop– nic nie rób i nic nie wysyłaj (np. sam reset).
Na wyjściu: { value, maxValue, direction, timestamp }. Węzły z wcześniejszych wersji używają nadal zakresu
flow, dopóki nie zmienisz go w formularzu.
Marcin Chuć · MIT
