node-red-contrib-advanced-ping-multiple 1.4.4
A Node-RED node which takes input and pings a remote server or multiple servers.
npm install node-red-contrib-advanced-ping-multiple
A Node-RED node which takes input and pings a remote server.
This is a modification of the node-red-node-ping node. Difference is that this node will perform a ping when it recieves input where the node-red-node-ping node performs pings on a set interval. You may also programmatically pass ping settings to this node. For periodical checks, wire an inject node to this ping node.
  • Pings an array of machines and returns the trip time in ms. Ping time is returned in msg.payload. Returns Int -1000 if no response received within given msg.timeout in seconds (5 seconds being the default value), or if the host is unresolveable.
  • Will perform ping on any input and only once per machine.
  • You may override the host set in the configuration by passing in a value in msg.host. msg.hostcan be an array of hosts. In that case msg.payload will be an array with the delays or -1000 when unreachable. Null positions of the array will be preserved and presented as null in the msg.pyload output.
  • You may set a timeout for each machine's ping by pasing a value in seconds in msg.timeout. Also a delay between pings to different servers can be set by passing a value in miliseconds in msg.delta. Default values are 5 seconds and 25 miliseconds if no value is set on those message properties.
  • For legacy reasons, the node will output the host as msg.topic (the original node-red-node-ping does it this way).
  • Any incomming data will be passed on to the output.
    • Incoming msg.payload data will be outputted as msg._payload (as the new msg.payload will contain the result of the ping).
    • Incoming msg.topic data will be outputted as msg._topic (as the new msg.topic will contain the the host).
Todo
Ability to set ping options in node configuration/by incomming message. Right now, these settings are hardcoded except timeout. Default is 5secs but you can override it by passing a msg.timeout value in seconds.
  • Linux: -n -w timeout -c 1
  • Windows: -n 1 -w timeout x1000
  • Mac: -n -t timeout -c 1
Version: 1.4.4
Updated 2 years, 4 months ago
License: Apache
50 in the last week
  • ping-many
  • node-red-contrib-multiple
  • contrib
  • ping
