node-red-contrib-ads1x15_i2c 0.0.14
A node-red node providing access to a ADS1x15 I2C analog to digital converter
npm install node-red-contrib-ads1x15_i2c
Node-RED A node-red node providing access to a ADS1x15 I2C analog to digital converter.
ads1x15_i2c Documentation
Guide for the ADS
Configuring I2C on the Raspberry Pi
Configuring Software I2C on the Raspberry Pi
This Node should work for any working i2c device on non raspberry pi based systems!
Table of Contents
Install with node-red Palette Manager or,
Run the following command in your Node-RED user directory - typically ~/.node-red:
To get a voltage or difference of voltage from a ADS1115 or ADS1015 analog to digital converter just select the correct setting for your device and trigger the node.
Name
Define the msg name if you wish to change the name displayed on the node.
Property
Define the msg property name you wish. The name you select (msg.example) will also be the output property
The payload must be a number! Anything else will try to be parsed into a number and rejected if that fails.
Chipset
The Chipset by default is set to 1115. The Chipset is the version of ads supported. If you have an ads1015 select that option.
i2c_Address
The Address by default is set to 0x48. You can setup the ADS1X15 with one of four addresses, 0x48, 0x49, 0x4a, 0x4b. Please see ads1X15 documentation for more information
Inputs
Inputs may be used for Single-ended measurements (A0-GND) or Differential measurements (A0-A1). Single-ended measurements measure voltages relative to a shared reference point which is almost always the main units ground. Differential measurements are “floating”, meaning that it has no reference to ground. The measurement is taken as the voltage difference between the two wires. Example: The voltage of a battery can be taken by connecting A0 to one terminal and A1 to the other.
Samples
Select the sample per second you want your ADS to make. Higher rate equals more samples taken before being averaged and sent back from the ADS. Please see ads1X15 documentation for more information
Gain
I Select the Gain you want. To increase accuracy of smaller voltage signals, the gain can be adjusted to a lower range. Do NOT input voltages higher than the range or device max voltage, pi 3.3v use a voltage devider to lower input voltages as needed.
Bugs / Feature request
Please report bugs and feel free to ask for new features directly on GitHub.
This project is licensed under Apache 2.0 license.
Work
_Need a node? _Need automation work? _Need computers to flip switches?
Contact me at [email protected]
Contributor_of_Project
Thanks to Kevin Felix D Rodriguez Perez AKA felixdrp for his work on ads1x15. It made making this node for node-red possible.
release notes
0.0.0 = (majorchange) . (new_feature) . (bugfix-simple_mod)
version 0.0.14
Update Documentation
version 0.0.13
version 0.0.12
version 0.0.11
First Public release
Version: 0.0.14
Updated 5 years, 8 months ago
Rating: 5.0 2
34 in the last week
  • ads1x15_i2c
  • ads1115
  • ads1015
  • ads1x15
  • ads
  • adc
  • analog to to digital converter
  • digital converter
