node-red-contrib-ads-client 2.0.1
Beckhoff TwinCAT ADS client library for Node-RED (unofficial). Connects to Beckhoff TwinCAT automation systems using ADS protocol.
npm install node-red-contrib-ads-client
npm version GitHub License
Connect to a Beckhoff TwinCAT automation system using the ADS protocol from Node-RED. This is a wrapper over the battle-tested ads-client Node.js library.
Project status
25.10.2025 - version 2 released!
  • Supports TwinCAT 2 and 3
  • Supports connecting to the local TwinCAT 3 runtime
  • Supports any kind of target systems with ADS protocol (local runtime, PLC, EtherCAT I/O...)
  • Supports multiple connections from the same host
  • Reading and writing any kind of variables
  • Subscribing to variable value changes (ADS notifications)
  • Automatic conversion between PLC and Javascript objects
  • Calling function block methods (RPC)
  • Automatic 32/64 bit variable support (PVOID, XINT, etc.)
  • Automatic byte alignment support (all pack-modes automatically supported)
  • Handles TwinCAT restarts, configuration changes and PLC software updates automatically
Support
If you want to support my work, you can buy me a coffee! Contact for more options.
Buy Me A Coffee
Donate
If you need help with integrating the ads-client, I'm available for coding work with invoicing. Contact for further details.
Installing
npm i node-red-contrib-ads-client
Documentation
Please see ads-client documentation for more details and help. This is just a wrapper over it so documentation is kept short.
Each node has its own built-in documentation - see the help under each node in Node-RED.
Available nodes
NOTE: At the moment, not all ads-client features are converted to the Node-RED nodes. This will hopefully improve in the future - contributions are welcome!
Node Description Equivalent in ads-client
ADS - Connection Status Reports status changes of the selected ADS connection. connect, disconnect and reconnect events
ADS - Read Value Reads variable's value from the target system by a variable path (such as GVL_Test.ExampleStruct) and returns the value as a Javascript object. readValue()
ADS - Write Value Writes variable's value to the target system by a variable path (such as GVL_Test.ExampleStruct). Converts the value from a Javascript object to a raw value. writeValue()
ADS - Subscribe Value Subscribes to value change notifications (ADS notifications) by a variable path, such as GVL_Test.ExampleStruct. subscribeValue()
ADS - Invoke RPC Method Invokes a function block RPC method on the target system. invokeRpcMethod()
ADS - Read PLC Runtime State Reads target PLC runtime state (Run, Stop etc.) readPlcRuntimeState()
ADS - Read TC System State Reads target TwinCAT system state from ADS port 10000 (usually Run or Config). readTcSystemState()
ADS - Read TC System Extended State Reads extended target TwinCAT system service state from ADS port 10000 if supported by target system. Extended version of the Read TC System State. readTcSystemExtendedState()
ADS - Get Symbols Returns all symbols from the target PLC runtime. getSymbols()
ADS - Get Symbol Returns a symbol object for given variable path (such as GVL_Test.ExampleStruct). getSymbol()
ADS - Read Raw Reads raw data from the target system by a raw ADS address (index group, index offset and data length). readRaw()
ADS - Write Raw Writes raw data to the target system by a raw ADS address (index group, index offset and data length). writeRaw()
ADS - Convert To Raw Converts a Javascript object to raw data by using the provided data type. convertToRaw()
ADS - Convert From Raw Converts raw data to a Javascript object by using the provided data type. convertFromRaw()
Getting started
After you have installed the package and restarted Node-RED, you should see ADS nodes in the node list.
Adding a connection
  1. Drag any ADS node to the flow, such as ADS - Read Value
  2. Double click the node
  3. Next to ADS connection setting, press + button to add a new connection
  1. Enter a friendly name to the connection
  2. Enter target settings
  3. Press Add. A new ADS connection is created.
Examples
The ./examples/example-all-nodes.json includes an example for each node. Import it to Node-RED to test it.
The example connects to a PLC runtime at 192.168.4.1.1.1 (local usermode runtime) and requires a running ads-client-test-plc-project.
FAQ
If you have issues, they are probably related to ads-client instead of the NodeRED version.
See ads-client README
Licensed under MIT License.
Copyright (c) Jussi Isotalo <[email protected]>
Version: 2.0.1
Updated 8 months, 1 week ago
Rating: 5.0 3
123 in the last week
  • ads-client-connection
  • ads-client-connection-status
  • ads-client-read-value
  • ads-client-write-value
  • ads-client-subscribe-value
  • ads-client-invoke-rpc-method
  • ads-client-read-plc-runtime-state
  • ads-client-read-tc-system-state
  • ads-client-read-tc-system-extended-state
  • ads-client-get-symbols
  • ads-client-read-raw
  • ads-client-write-raw
  • ads-client-convert-to-raw
  • ads-client-convert-from-raw
  • ADS
  • twincat
  • beckhoff
  • plc
  • iec-61131-3
  • 61131-3
  • twincat 2
  • twincat 2.11
  • twincat 3
  • twincat 3.1
  • twincat ADS
  • codesys
  • client
