node-red-contrib-adanos 0.1.1
Node-RED nodes for Adanos stock and crypto market sentiment
npm install node-red-contrib-adanos
Adanos nodes for Node-RED
Use the Adanos Market Sentiment API in Node-RED flows. The package provides focused nodes for stock details, crypto details, trending assets, and comparisons across Reddit, News, X/Twitter, and Polymarket.
Install from the Node-RED Palette Manager by searching for node-red-contrib-adanos, or run this command in the Node-RED user directory:
Node.js 18 or newer and Node-RED 4 or newer are required.
Configure
  1. Add any Adanos node to a flow.
  2. Create an Adanos API configuration from its API field.
  3. Enter your Adanos API key and deploy the flow.
The API key is stored as a Node-RED credential. It is not included when flows are exported.
Node Purpose
Adanos stock Detailed stock sentiment from Reddit, News, X/Twitter, or Polymarket
Adanos crypto Detailed Reddit sentiment for a crypto token
Adanos trending Trending stocks or crypto tokens for a selected market
Adanos compare Compare up to 10 stock tickers or crypto symbols
Each node preserves the incoming message and writes the exact SDK response to msg.payload. If msg.topic is empty, the node sets a topic such as adanos/reddit/stock/TSLA.
Inputs and overrides
Ticker, symbol, and compare assets use Node-RED typed inputs. They may come from the message, a literal value, flow/global context, or an environment variable. Compare assets may be an array or a comma-separated string.
Optional request settings can be configured on the node or overridden per message:
  "ticker": "NVDA",
  "adanos": {
    "from": "2026-07-01",
    "to": "2026-07-07",
    "limit": 10,
    "offset": 0
Supported msg.adanos fields:
  • All nodes: from, to, days
  • Trending: limit, offset
  • News trending: source
  • Polymarket trending: type
Use from/to for an explicit inclusive UTC date window. Alternatively, use days; days may be combined with to, but not with from.
Errors and status
The nodes show their latest state below the node:
  • Blue dot: request in progress
  • Green dot: response received
  • Red ring: invalid input or API failure
Errors are passed to Node-RED's standard error handling, so a Catch node can route them without stopping the runtime.
Example flow
Open Import → Examples → node-red-contrib-adanos → Adanos market sentiment after installation. Configure its Adanos API credential before deploying.
Development
npm install
npm test
npm run check
For local Node-RED testing, run this from the Node-RED user directory and restart Node-RED:
npm install /absolute/path/to/node-red-contrib-adanos
The runtime uses the public finance-sentiment SDK rather than duplicating Adanos API request logic.
MIT
Version: 0.1.1
Updated 4 months ago
  • adanos-config
  • adanos-stock
  • adanos-crypto
  • adanos-trending
  • adanos-compare
  • adanos
  • stocks
  • crypto
  • sentiment
  • trending
  • finance
