node-red-contrib-acr122u_nfc 1.0.3
NFC acr122u card read node
npm install node-red-contrib-acr122u_nfc
A simple Node-RED node for working with ACR122U NFC readers using the nfc-pcsc library.
๐Ÿ“ฆ Installation
Before installing, you should have connected the reader at least once to the computer. Install via the Node-RED palette manager or with npm in your Node-RED user directory (usually ~/.node-red):
โš ๏ธ This node depends on the nfc-pcsc library. It will be installed automatically as a dependency.
if not use:
npm install nfc-pcsc
๐Ÿ–ง Requirements ACR122U or compatible NFC reader
PC/SC smart card service running (usually enabled by default on Windows/macOS)
๐Ÿ“š Usage This node listens for NFC tags placed on the ACR122U reader and outputs the tag's UID and other relevant info.
Output Message (msg) Card UID: 2467430b Card removed: { atr: <Buffer 2b 7f 80 01 80 4f 0c a0 01 00 03 06 03 00 01 00 00 00 00 6a>, standard: 'TAG_ISO_14443_3', type: 'TAG_ISO_14443_3', uid: '2677460b'
} Example Flow You can wire this node into a debug node or a function node to handle tag scans:
[acr122u] โ†’ [function] โ†’ [debug] โš™๏ธ Configuration This node requires no configuration โ€” just drop it in your flow and it starts listening for cards.
๐Ÿ’ก Notes Only one NFC reader is supported at a time.
Multiple scans may be emitted depending on tag polling behavior.
On Linux, you may need to add your user to the pcscd or plugdev group and ensure the pcscd daemon is running.
๐Ÿงช Development To test your custom node locally:
npm install /path/to/your/node-red-contrib-acr122u_nfc
Then restart Node-RED.
๐Ÿ“ License MIT
ยฉ 2025 Itu developments. Contributions welcome!
Version: 1.0.3
Updated 1 year, 7 months ago
20 in the last week
  • acr122u
  • arc122
  • card
  • desfire
  • mifare
  • ndef
  • nfc
  • pcsc
  • pcsclite
  • tag
