node-red-contrib-acepro 2.0.21
Provides control and feedback of the aceBUS connected devices (proprietary of company ACEPRO)
npm install node-red-contrib-acepro
Node-RED nodes to talk to aceBUS devices (proprietary of company ACEPRO).
Description
This package provides Node-RED nodes for communicating with ACEPRO devices via the aceBUS protocol. It includes nodes for both reading from and writing to ACEPRO devices over UDP.
The package provides several nodes for different use cases:
aceproNet (Configuration Node)
The main configuration node that handles UDP communication with aceBUS devices.
Configuration:
  • Name: Unique identifier for this connection
  • Broadcast Address: IP address for UDP broadcast
  • Port: UDP port number for communication
aceproIOID in/out
Basic input/output nodes for single IOID communication.
Input Node - Receives values from aceBUS devices:
  • Outputs received value in msg.payload
  • Topic format: {host}_{IOID}
Output Node - Sends values to aceBUS devices:
  • Input value from msg.payload
  • Must be numeric value
aceproMultiIOID in/out
Advanced nodes for handling multiple IOIDs simultaneously.
Configuration:
  • Multiple IOID definitions in JSON format
  • Supports grouping and statistical analysis
  • Optional live status display
Example Flow
        "id": "network1",
        "type": "aceproNet",
        "name": "ACEPRO Network",
        "BrAddress": "192.168.1.255",
        "port": "31456"
        "id": "input1",
        "type": "aceproIOID in",
        "network": "network1",
        "host": "192.168.1.100",
        "IOID": "1001",
        "LiveStatus": true
API
aceprolib
The package includes a library module with common utilities:
const aceprolib = require('node-red-contrib-acepro');
// Access constants
const cmdGetVal = aceprolib.constants.CMD_GetVal;
// Use utilities
const isEmpty = aceprolib.utils.isEmptyObject({});
Testing
Run the test suite with:
    npm test
Requirements
  • Node.js 10.0 or higher
  • Node-RED 1.0 or higher
Apache License 2.0 - See LICENSE file for details.
Support
For issues and questions, please use the GitHub issue tracker.
Version: 2.0.21
Updated 6 months, 3 weeks ago
25 in the last week
  • aceproNet
  • aceproIOID out
  • aceproIOID in
  • aceproMultiIOID out
  • aceproMultiIOID in
  • acepro
  • aldarna
  • acebus
