node-red-businesscentral 0.1.0
Node-RED node for Microsoft Dynamics 365 Business Central REST APIs
npm install node-red-businesscentral
Node-RED nodes for reading data from Microsoft Dynamics 365 Business Central REST APIs (built-in and custom APIs).
  • businesscentral-config config node for shared connection/auth settings
    • Tenant ID
    • Environment
    • Client ID / Client Secret
    • Custom API namespaces (publisher/group/version)
  • businesscentral-get node for data retrieval
    • Dynamic company and endpoint lookup
    • Built-in and extension endpoints
    • Optional field selection ($select)
    • Filter support ($filter) from config or msg.filterGroups
    • Dependency handling for parent/child endpoints (for example sales orders -> sales lines)
  • businesscentral-filter node to visually build msg.filterGroups
    • Group logic (and / or)
    • Conditions and nested groups
    • Dynamic templates from incoming message values ({{msg.payload.id}})
Option 1: Install from npm (recommended)
When published:
Option 2: Install locally for development
From your Node-RED user directory (typically ~/.node-red):
npm install <path-to-this-project>
Then restart Node-RED.
Node-RED Palette Manager
After publishing to npm, this package can be added from Manage palette in Node-RED by searching:
  • node-red-businesscentral
Quick Start
  1. Add a businesscentral-config node and fill:
    • Tenant ID
    • Environment name
  2. Add businesscentral-get and select:
    • Config node
    • Company
    • Endpoint
  3. (Optional) Add businesscentral-filter before businesscentral-get to build advanced filters.
  4. Deploy and trigger with an Inject node.
Message contract
Input overrides supported by businesscentral-get:
  • msg.company
  • msg.companyName
  • msg.endpoint
  • msg.selectedFields (array or comma-separated string)
  • msg.filterGroups
  • msg.query (additional query parameters)
Output:
  • msg.payload - API response rows/object
  • msg.statusCode - HTTP status
  • msg.bc - metadata (requestUrl, requestId, appliedFilter, endpoint/company context)
Permissions and authentication
The node uses OAuth2 client credentials against Business Central API scope:
  • https://api.businesscentral.dynamics.com/.default
Ensure your Azure app registration has required Business Central API application permissions with admin consent.
Development
Run tests:
npm test
Packaging checklist
Before publishing:
  1. Update package.json:
    • name (must be unique on npm)
    • version
    • author
    • repository, homepage, bugs
  2. Verify with:
    • npm pack
  3. Publish:
    • npm publish
MIT - see LICENSE.
Version: 0.1.0
Updated 8 months ago
  • node-red-node
  • business-central
  • dynamics-365
  • odata
