node-red-azure-iot-central 0.0.2
Node-RED node for Azure IoT Central — telemetry, commands, and device twin via MQTT/AMQP/HTTP using the official Azure IoT SDK
npm install node-red-azure-iot-central
A Node-RED node for connecting devices to Azure IoT Central using the official Azure IoT SDKs. Supports DPS auto-provisioning, telemetry, cloud-to-device commands, and device twin (desired/reported properties) over MQTT, AMQP, or HTTP.
  • DPS auto-provisioning — register devices automatically through global.azure-devices-provisioning.net
  • Persistent connection with exponential-backoff reconnection (2 s → 60 s)
  • Multiple transports — MQTT (recommended), AMQP, HTTP
  • Authentication — SAS Symmetric Key or X.509 certificates
  • Telemetry — send JSON payloads device → cloud
  • Cloud commands — receive method invocations from IoT Central with auto-ACK on timeout
  • Device twin — desired-property delta with automatic version-stamped acknowledgment, plus reported properties
  • IoT Plug and Play — optional componentName for component-scoped telemetry
  • Per-instance state — multiple device nodes run independent connections
From the Node-RED UI: Manage palette → Install and search for node-red-azure-iot-central.
Or from the user data directory (~/.node-red):
Requires Node.js ≥ 18 and Node-RED ≥ 3.0.
azure-iot-central-config (configuration node)
Holds device credentials, reusable across multiple device nodes.
Field Description
Scope ID DPS ID Scope (IoT Central → Administration → Device connection)
Device ID Must match the device registered in IoT Central
Transport mqtt (default), amqp, or http
Auth sas (Symmetric Key) or x509 (Certificate)
Primary Key SAS primary key (encrypted at rest)
Cert File / Key File / Passphrase X.509 certificate paths and key passphrase
azure-iot-central-device
Maintains the persistent connection. 1 input, 3 outputs.
Port Direction Purpose
Input flow → cloud Telemetry or reported properties
Output 1 cloud → flow Commands received from IoT Central
Output 2 cloud → flow Desired-property changes
Output 3 flow → flow Status events (connected, telemetry_sent, reported_sent, error)
1. Send telemetry
Wire any node (e.g. inject, function) into the input. Default msg.topic is telemetry.
msg.payload = { temperature: 22.5, humidity: 47 };
Optional fields:
Property Type Notes
msg.topic string telemetry (default) or reported
msg.payload object | string Telemetry data or reported-properties patch
msg.componentName string IoT Plug and Play component name ($.sub)
msg.messageId string IoT Hub message ID
2. Update reported properties
msg.topic   = 'reported';
msg.payload = { firmwareVersion: '1.4.2', uptime: 3600 };
Reported properties require MQTT or AMQP — HTTP transport is telemetry-only.
3. Handle cloud commands (Output 1)
In the device node config, list the command names (one per line). Wire Output 1 into a function node and call msg._respond(statusCode, payload) to acknowledge:
if (msg.methodName === 'reboot') {
    // do work...
    msg._respond(200, { status: 'rebooting' });
return null; // do not forward downstream
If you do not respond within 30 seconds, the node auto-ACKs with status 200 and payload { status: 'ack_timeout' } to prevent hung requests on the IoT Central side.
4. React to desired-property changes (Output 2)
// msg.topic   === 'desired'
// msg.payload === { setpoint: 21, mode: 'auto' }
// msg.version === <twin version>
Acknowledgment back to IoT Central is automatic — each property is reported with { value, ad: 'success', ac: 200, av: <version> }.
5. Monitor status (Output 3)
{ topic: 'connected',      payload: { hub, deviceId } }
{ topic: 'telemetry_sent', payload: { payload } }
{ topic: 'reported_sent',  payload: { payload } }
{ topic: 'error',          payload: { operation, error } }
Example flow
  {"id":"f1","type":"tab","label":"IoT Central","disabled":false,"info":""},
  {"id":"i1","type":"inject","z":"f1","name":"every 30s","props":[{"p":"payload"}],"repeat":"30","payload":"{\"temperature\":22.5}","payloadType":"json","x":160,"y":120,"wires":[["d1"]]},
  {"id":"d1","type":"azure-iot-central-device","z":"f1","name":"Device","server":"cfg1","commands":"reboot\nfirmwareUpdate","x":380,"y":160,"wires":[["cmd"],["desired"],["status"]]},
  {"id":"cmd","type":"debug","z":"f1","name":"Command","active":true,"x":600,"y":120,"wires":[]},
  {"id":"desired","type":"debug","z":"f1","name":"Desired","active":true,"x":600,"y":160,"wires":[]},
  {"id":"status","type":"debug","z":"f1","name":"Status","active":true,"x":600,"y":200,"wires":[]},
  {"id":"cfg1","type":"azure-iot-central-config","name":"my-device-01","scopeid":"0ne00000000","deviceid":"my-device-01","transport":"mqtt","auth":"sas"}
Replace scopeid, deviceid, and the SAS primary key (set in the config node UI) with values from your IoT Central application.
Transport feature matrix
Feature MQTT AMQP HTTP
Telemetry ✓ ✓ ✓
Cloud commands ✓ ✓ ✗
Reported properties ✓ ✓ ✗
Desired properties ✓ ✓ ✗
DPS provisioning ✓ ✓ ✓
MQTT is the default and recommended transport.
Troubleshooting
Symptom Likely cause
Status DPS failed Wrong Scope ID, wrong Device ID, or wrong primary key
Status Connect failed after DPS OK Device disabled in IoT Central, or wrong key signature
Repeated Reconnecting in Ns… Network issue or invalid credentials — check Node-RED debug log
Commands never arrive HTTP transport selected, or command names not listed in the device node
Reported properties not available warning HTTP transport — switch to MQTT/AMQP
Enable verbose logging by setting Node-RED's log level to debug in settings.js.
Contributing
Issues and pull requests are welcome on GitHub.
MIT © Robert Benavides
Version: 0.0.2
Updated 6 months, 2 weeks ago
  • azure-iot-central-config
  • azure-iot-central-device
  • azure
  • iot
  • iot-central
  • iothub
  • mqtt
  • amqp
  • dps
  • provisioning
  • telemetry
  • device-twin
  • Jorge Ortega
  • William Cepeda
  • Robert Benavides
