node-red-axios-wrapper 1.0.1
axios wrapper node
npm install node-red-axios-wrapper
Node-RED Axios Wrapper
axios wrapper node
Overview
This provides a generic wrapper function for Axios, enabling you to make HTTP requests within Node-RED with configurations similar to those used in Postman. The function follows the subscribe pattern and is designed to be easily integrated into your Node-RED workflows.
Parameters
  • config (Object): The request configuration object that should include properties like url, method, headers, params, and data.
Returns
A Promise that resolves with the response data as a JSON object.
Usage in Node-RED Subflow
The function is executed using the subscribe pattern, which means it will process incoming messages (msg.payload) containing request configurations:
return axiosWrapper(msg.payload)
  .then(responseData => {
    msg.payload = responseData;
  .catch(error => {
    msg.payload = { status: 'error', message: error };
Functionality
  1. Header Configuration:
    • Merges any headers provided in the config with a default 'Content-Type' of 'application/json'.
  2. Request Configuration:
    • Constructs the request configuration using properties from the input config (url, method, headers, params, and data).
  3. Debug Logging (if enabled):
    • Logs the request configuration to the Node-RED console if debugging is enabled globally.
  4. HTTP Request Execution:
    • Uses Axios to make the HTTP request.
    • Resolves with response data on success.
    • Rejects with an error message if the request fails.
Example Input Message (msg.payload)
  "url": "https://api.example.com/data",
  "method": "POST",
  "headers": {
    "Authorization": "Bearer <token>"
  "data": {
    "key1": "value1"
Example Output Message (msg.payload)
  • Success: Contains the response data from the API.
  • Error: Contains a status of 'error' and the error message.
  1. Clone this repository or download the subflow file directly.
  2. Import the subflow into your Node-RED instance via the "Import" feature in the Node-RED UI.
Dependencies
  • Axios: Ensure you have Axios installed in your Node-RED environment to use this wrapper function.
npm install axios
  • The config object should contain at least a url and a method. Other properties like headers, params, and data are optional but commonly used.
Debugging
Set the global debug setting in Node-RED to enable logging of request configurations:
global.set('debug', true);
This will print out the request configuration being sent via Axios to help with debugging issues.
This subflow function is designed to simplify making HTTP requests within Node-RED by leveraging Axios while maintaining flexibility similar to Postman configurations.
Version: 1.0.1
Updated 1 year, 6 months ago
  • node-red-subflow
  • axios
  • rest
  • api
  • postman
