node-contrib-inovelli-status-manager 0.1.0
Status manager node for inovelli switch
npm install node-contrib-inovelli-status-manager
Inovelli Status Manager Node
This node allows you to easily set the appropriate value to send to your Inovelli red or blue series switches.
Z-wave (red) switches w/ zwave_js
This node should be used in conjunction with the node-red–contrib-home-assistant add on and the output should be connected to a api-call-service node that is set to the domain zwave_js and the service bulk_set_partial_config_parameters. You can set the entity ID to your z-wave switch. DO NOT set the Node ID on the status manager node as it isn't needed when you set bulk_set_partial_config_parameters to point to an entity id.
Quick start guide
There are example flows for red switches to zwave_js service call nodes and blue switches to either native mqtt out or home assistant mqtt.publish nodes
Zigbee (blue) switches
There is currently support for constructing a MQTT payload for full LED control for Zigbee2MQTT users. (Individual control might be coming soon but will be trickier). When using this node with home assistant it can be connected directly to an api-call-service node calling mqtt with the service publish. You will want to set the topic to zigbee2mqtt/FRIENDLY_NAME/set.
Node-RED mqtt out node
You can wire the configration node directly to the mqtt out node. You just need to set the topic zigbee2mqtt/FRIENDLY_NAME/set.
Home Assistant MQTT Publish node
The mqtt.publish service only supports string payloads so you have to stringify the output and pass it to the payload. There is an example that does this using a function node but there are multiple ways to do this (e.g. )
Contributing
If you notice any problems open an issue or a pull request. Thanks.
Version: 0.1.0
12 in the last week
  • inovelli-status-manager
