ncd-red-ads7828 1.1.5
This library provides a class for the ADS7828, it relies on the ncd-red-comm library for communication, and includes a node-red node for the ADS7828. The ADS7828 is an 8-channel, 12-bit, I2C compatible, analog-to-digital converter. [Ncd.io](https://ncd.io
npm install ncd-red-ads7828
ADS7828
This library provides a class for the ADS7828, it relies on the ncd-red-comm library for communication, and includes a node-red node for the ADS7828. The ADS7828 is an 8-channel, 12-bit, I2C compatible, analog-to-digital converter. Ncd.io manufactures a full breakout board that utilizes this chip, you can find it here.
ADS7828
This library can be installed with npm with the following command:
For use in node-red, use the same command, but inside of your node-red directory (usually ~./node-red).
The test.js file included in this library contains basic examples for use. The datasheet contains more information on specific settings. All of the available configurations are available in the node-red node through the UI.
Raspberry Pi Notes
If you intend to use this on the Raspberry Pi, you must ensure that:
  1. I2C is enabled (there are plenty of tutorials on this that differ based on the Pi version.)
  2. Node, NPM, and Node-red should be updated to the LTS versions. If you skip this step the ncd-red-comm dependency may not load properly.
Version: 1.1.5
Updated 8 years, 3 months ago
4 in the last week
  • ncd-ads7828
  • ADS7828
  • ncd
  • ADC
  • i2c
