mpowr-it-node-red-sentry-node 1.1.0
A sentry API wrapper node for Node-RED
npm install mpowr-it-node-red-sentry-node
Checks
Node-RED Sentry Node
This package provides a custom node for Node-RED that wraps the Sentry API for sending captured errors to your sentry project.
Install via Node-RED Manage Palette
Open your Node-RED instance and go to Manage palette and search for mpowr-it-node-red-sentry-node. Press the install button to install the node.
Install via npm
  1. Pull the sentry node — you can find it in the "function" section of the palette — and drop it on the flow.
  2. Double click the sentry node to configure it (see Node properties below).
  3. Drop a catch node (from "common" section) to capture all errors in the flow.
  4. Connect the catch node to the sentry node.
That's it.
Screenshot sentry node attached to catch-all node
Node properties
DSN
This is the unique identifier of your sentry project. You can find it in your sentry project settings under Client Keys (DSN).
Environment
This tells Sentry which environment the error occurred in.
Please note: You can also set the environment via the ENVIRONMENT environment variable.
If both are set, the node property takes precedence.
Per message configurations
The sentry node will look for the property msg.sentry and if found, any supported config will be set which is contained in the property.
Supported msg.sentry configurations
User information
  "user": {
    "id": "U123456",
    "username": "jdoe",
    "email": "[email protected]",
    "ip_address": "127.0.0.1"
Additional tags
  "tags": {
    "some-tag-key-1": "some-tag-value-1",
    "some-tag-key-n": "some-tag-value-n"
How does it work?
If the msg object carries an error on its property msg.error it will be used and sent to your sentry instance. If the message objects also contains a msg._error property it will be added as breadcrumb for the error sent.
Return value
The node will return a payload of type object having a boolean sent property that indicates if the error has been sent to your Sentry project or not.
Please Note: true does not mean that the error was sent to your Sentry instance successfully, as it may fail due to invalid DSN for example, but it means that this node captured the error, parsed it, and executed Sentry.captureException.
Development
Prerequisites
  • docker-compose v2.0.0 or higher
Setup
Clone the repository and run:
make serve
This will start a local Node-RED instance with the sentry node installed.
The web UI under http://127.0.0.1:1880/ will automatically open in your browser.
Testing
make test
Tear down
make stop
Version: 1.1.0
Updated 3 years, 5 months ago
21 in the last week
  • sentry-wrapper
  • api-wrapper
  • sentry
