iglass-nodes 0.0.37
Node-RED contribution package with nodes for interaction with iGlass Automation blocks.
npm install iglass-nodes
iglass-nodes
Node-RED contribution package with nodes for interaction with iGlass Automation blocks and build your UI.
Follow us on Telegram and Instagram.
Nodes description
UI nodes
UI nodes provide building your own UI. Easily control any your devices in Node-Red with UI nodes.
You can download free mobile apps to use your UI.
iOsAndroid
Functional nodes
iGlass-Ajax
Node for receiving statuses from Ajax sensors that was paired with iGlass blocks. Blocks currently supported include:
iGlass-Ajax-add
Node for pairing Ajax sensors with iGlass blocks. Blocks currently supported include:
iGlass-Ajax-delete
Node for remove all Ajax sensors that was paired with iGlass blocks. Blocks currently supported include:
iGlass-1-wire
Node for get temperature from 1-wire sensor, connected to Smart Server block.
iGlass-analog-input
Node for get value of analog 0-10V input of iGlass blocks. Blocks currently supported include:
iGlass-analog-output
Node for control analog 0-10V output of iGlass blocks. Blocks currently supported include:
iGlass-digital-input
Node for get value of digital input of iGlass blocks. Blocks currently supported include:
iGlass-digital-output
Node for control digital output of iGlass blocks. Blocks currently supported include:
iGlass-dimmer-output
Node for control dimmer output of iGlass blocks. Blocks currently supported include:
iGlass-DMX
Node for interaction iGlass blocks with DMX512 devices. Blocks currently supported include:
iGlass-modbus-RS485
Node for sending Modbus requests in RS485 bus from iGlass Smart Server block and Server Yocto. Function codes currently supported include:
  • FC 1: Read Coil Status
  • FC 2: Read Input Status
  • FC 3: Read Holding Registers
  • FC 4: Read Input Registers
  • FC 5: Force Single Coil
  • FC 6: Force Single Register
  • FC 15: Force Multiple Coils
  • FC 16: Force Multiple Registers
iGlass-RS485-in
Node for reading RS485 messages from iGlass blocks. Blocks currently supported include:
iGlass-RS485-out
Node for sending RS485 messages from iGlass blocks. Blocks currently supported include:
Authors
iGlass Automation
Version: 0.0.37
Updated 4 years, 8 months ago
Rating: 5.0 245
4 in the last week
  • iGlass-digital-input
  • iGlass-digital-output
  • iGlass-analog-input
  • iGlass-analog-output
  • iGlass-1-wire
  • iGlass-RS485-in
  • iGlass-RS485-out
  • iGlass-DMX
  • iGlass-dimmer-output
  • iGlass-DMX-mode-config
  • iGlass-DMX-sending-period-config
  • iGlass-modbus-RS485
  • iGlass-RS485-baud-rate-config
  • iGlass-Ajax
  • iGlass-Ajax-add
  • iGlass-Ajax-delete
  • iGlass-Ajax-protection
  • iGlass-ZigBee
  • iGlass-ZigBee-add
  • iGlass-ZigBee-delete
  • iGlass-thermostat-RS485
  • iGlass-ui-switch
  • iGlass-ui-dimmer
  • iGlass-ui-rgb
  • iGlass-ui-rgbw
  • iGlass-ui-warm-cold
  • iGlass-ui-thermostat
  • iGlass-ui-status
  • iGlass-ui-curtains
  • iGlass-ui-notification
  • iGlass-ui-scene
  • iGlass-ui-room-config
  • iGlass-ui-category-config
  • iglass-automation
  • iglass
  • iot
  • smarthome
  • smart
  • home
  • homekit
  • dmx
  • 1-wire
  • modbus
  • rs485
  • dimmer
  • rgbw
  • rgb
  • led
  • ajax
  • zigbee
  • 0-10v
