hdl-automation-nodered 1.9.7
Provides control and feedback of the HDL Automation bus for Node Red https://www.hdlautomation.com/
npm install hdl-automation-nodered
HDL Automation for Node Red
Provides control and feedback of the HDL Automation bus.
HDL Automation
This project is no longer being maintained.
Don't stress! The HDL bus is unlikely to be changed in the near future so it is likely that this project will still work! I will keep the project open if you wish to contribute to the project.
How to Use
You require some way of communicating with the bus though network. This can be done by using a HDL-MBUS01IP.431 or HDL-MD512-DMX.232 (SB-DN-512DMX) (which is what this is tested on) or any other gateway that provides programming functionality to connect your bus to the network.
Sending to the bus
In order to send commands to the HDL bus it is expected that messages will be sent as following
var msg = {
    "payload": {
        "operate": "function", (required)
        "subnetId": 0, //Override the subnet id
        "deviceId": 1, //Override the device id
        "mode": "set/get", //Set will set the value to the bus, get will get the value from the bus (required)
        "direction": "request/answerBack", //Request is requesting the action to happen, answerBack is a reply from the bus (required)
        "data": {
            //The data specific to the function (see below)
Receiving from the bus
When events occur on the bus commands will be outputted in the following format:
    "payload": {
        "opCode": 0x002,
        "sender": { //The device that sent the message
            "deviceType": 0x00B,
            "subnetId": 1,
            "deviceId": 2,
            "wasSendToThisDevice": true/false
        "target": { //The target device for the sent message
            "subnetId" : 1
            "deviceId": 3
        "mode": "set/get",
        "data": {
        "contents": Buffer([0x01, 0x01]) //The raw contents sent
Supported Functions
Scene Control
Gets/Sets a scene on an area for a device
Sequence Control
Gets/Sets a sequence on an area for a device
UV Switch
Gets/Sets a a universal switch value on a device
Single Channel Control
Gets/Sets a single channel on a device
Date Time
Gets the date/time
AC Control
Controls a HVAC device (See panel control as some devices use the panel)
Panel Control
Controls a individual control panel, including AC control if controlled via a panel
Dry Control
Gets the value of a dry contact, useful for PIRs
Version: 1.9.7
Updated 4 years, 2 months ago
Rating: 3.0 2
4 in the last week
  • hdl-network
  • hdl-device
  • hdl-bus
  • hdl
  • automation
  • hdl automation
  • bus pro
  • bus
  • pro
