factory-agent-states 1.1.8
Node-RED node for factory agent states management
npm install factory-agent-states
node-red-contrib-factory-agent-states
A Node-RED node for factory agent systems that collects and manages state information from multiple MQTT topics.
Overview
The factory-agent-states node is designed to work within factory automation systems using agents. It provides a way to:
  • Cache incoming messages from different MQTT topics
  • Store system prompts and environment descriptions for agents
  • Output collected states when triggered by a specific signal
  • Clear the cache after output for the next cycle
You can install this node directly from the Node-RED palette manager, or via npm:
npm install node-red-contrib-factory-agent-states
  • Caching system: Stores the latest message from each topic until triggered
  • Configurable fields: Allows setting System Prompt and Environment Description
  • Initial delay: Automatically sends the first state after a configurable delay upon receiving the first message
  • Trigger mechanism: After the first automatic trigger, constantly monitors the flow context variable agentstate and outputs cached states when it equals "recieved"
  • Automatic cache clearing: Clears the topic cache after sending out the state
Node Configuration
The node provides a simple configuration interface with the following options:
  • Name: Optional name for the node instance
  • System Prompt: Text to be stored in msg.sysPrompt
  • Environment Description: Text to be stored in msg.envPrompt
Input
The node accepts messages with payloads that will be cached based on their topics.
Flow Context Variables
The node monitors a flow context variable:
  • agentstate: When this variable is set to "recieved", the node will output all cached states and then reset the variable
Output
When triggered, the node will output a message containing:
  • msg.sysPrompt: The System Prompt configured in the node
  • msg.envPrompt: The Environment Description configured in the node
  • msg.state: An object containing all cached topic payloads, with topics as keys
Usage Example
  1. Add MQTT input nodes for various factory sensors/data sources
  2. Connect these to the factory-agent-states node
  3. Configure the node with appropriate prompts and descriptions
  4. Set up a trigger mechanism (e.g., a function node that sets the flow context variable: flow.set("agentstate", "recieved"))
  5. Connect the output to your agent processing node
Example Flow
        "id": "mqtt1",
        "type": "mqtt in",
        "topic": "factory/temperature",
        "wires": [["factory-states"]]
        "id": "mqtt2",
        "type": "mqtt in",
        "topic": "factory/pressure",
        "id": "factory-states",
        "type": "factory-agent-states",
        "name": "Factory States",
        "systemPrompt": "You are a factory optimization agent",
        "environmentDescription": "Factory with temperature and pressure sensors",
        "wires": [["agent-processor"]]
        "id": "trigger",
        "type": "function",
        "payload": "",
        "payloadType": "str",
        "repeat": "300",
        "func": "flow.set('agentstate', 'recieved');\nreturn msg;",
MIT
Version: 1.1.8
Updated 1 year, 7 months ago
Rating: 5.0 4
16 in the last week
  • factory-agent-states
  • factory
  • agent
  • state
  • states
