factory-agent-deepseek 1.1.1
Node-RED node for interfacing with Deepseek AI API
npm install factory-agent-deepseek
If you dont give a shit about agent, u can throw msg.payload to this node and it will send it to deepseek.
Node-RED factory-agent-deepseek
A Node-RED node for interacting with Deepseek's AI API to create agent-based systems. This node is designed to simplify the process of sending prompts to Deepseek's models and handling responses within Node-RED flows.
  • Compose and send requests to Deepseek API with minimal configuration
  • Support for both deepseek-chat and deepseek-reasoner models
  • Combines environment, state, and action data into JSON format for user messages
  • Configurable temperature and max tokens settings
  • Secure API key storage
Install via Node-RED's Manage Palette:
  1. In Node-RED, navigate to the menu → Manage palette
  2. Go to the "Install" tab
  3. Search for "factory-agent-deepseek"
  4. Click install
Or install via npm:
Node Configuration
  1. Drag the factory-agent-deepseek node from the factory category in the palette to your flow
  2. Double-click the node to open the configuration panel
  3. Enter your Deepseek API key directly in the node configuration
  4. Select the model (deepseek-reasoner or deepseek-chat)
  5. Adjust temperature and max tokens settings if needed
  6. Click Done to save
Input
The node expects the following input properties:
  • msg.sysPrompt (string): The system prompt to send to Deepseek's system role
  • msg.envPrompt (string): Environment prompt to be combined with state and action
  • msg.state (string): State information to be combined with envPrompt and action
  • global.action (string): Action information from global context
Output
The node outputs:
  • msg.payload (object): The complete response from Deepseek API
  • msg.deepseekRequest (object): The request that was sent to Deepseek API
  • msg.result (string): The content from the Deepseek response message
  • msg.reasoning_content (string): The reasoning_content from the Deepseek response (if available)
Flow Context
The node manages a flow context variable:
  • flow.agentstate: Tracks the request status
    • processing: Set when the request is sent to Deepseek API
    • received: Set when a successful response is received
Example Flow
[{"id":"f6f2187d.f17ca8","type":"factory-agent-deepseek","z":"34de40b2.eb705","name":"Deepseek Agent","model":"deepseek-reasoner","temperature":"0.7","maxTokens":"2048","x":450,"y":300,"wires":[["c234a454.0cb648"]],"credentials":{"apiKey":"YOUR_API_KEY_HERE"}},{"id":"5a35c1ae.5e231","type":"inject","z":"34de40b2.eb705","name":"Test Input","props":[{"p":"sysPrompt","v":"You are a helpful assistant.","vt":"str"},{"p":"envPrompt","v":"Current time: 14:30","vt":"str"},{"p":"state","v":"User asked about weather.","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":270,"y":300,"wires":[["f6f2187d.f17ca8"]]},{"id":"c234a454.0cb648","type":"debug","z":"34de40b2.eb705","name":"Response","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":640,"y":300,"wires":[]}]
Files
The node includes the following files:
  1. factory-agent-deepseek.js - Main implementation
  2. factory-agent-deepseek.html - Configuration UI and help documentation
  3. package.json - Node-RED package information
  4. README.md - Documentation
MIT
Version: 1.1.1
Updated 1 year, 7 months ago
Rating: 4.4 10
10 in the last week
  • factory-agent-deepseek
  • deepseek
  • ai
  • factory
  • agent
