echar-checkdev 1.1.9
A Node-RED check tool to interact with UC20 / M3000 / M4000 for network device monitoring
npm install echar-checkdev
Echar-Check
This checktool will pool by IP or his Network name and returns the trip time in miliseconds as directly configured or by automated via msg.payload input command. It can be used as a triggered or timed configuration!
To a better result Best Practice
Regarding network issues and traffic protections
We will delay 100ms from each host to monitor
this will help to keep in a safe way and not be kicked from the network trafic, caused of fully load the network bandwidth
Ideal work scanning cyclically time window
consider to use injection each 2seconds or more
Ideal host quantities per cycle
keep maximum 20 hosts
Hash and Key
Parameters
If you have them, please fill-up the values on the right field.
Key and Hash are needed to activate the communication process
If you don't have it, please send a Telegram message to @echarcheck2DerBot with detail information:
  • Your information
  • UC20 / M3000 / M4000 frontal and side picture.
These informations are needed to we generate the proper Hash and Authorization Key!!
Active your check node online with Internet on port X1
Set as triggered option, send a payload
[{"host":"@echarcheck2DerBot","name":"Request"}]
to the node, to complete the request, once you recieve the Telegram message in return, please fulfilled both values, with they inserted, you can activate the check node!!
if you have nany trouble, send email to [email protected]
The Pair Hash & Key will be the same to all used nodes
  • Hash option
    Hash information to get from the supplier, this node will work only after properly set
  • Key option
    Unlock password to activate the node, this will allow the node to be activated
Output
payload number
the trip time in miliseconds, or boolean false if no response.
topic string
the target host or ip address.
[monitor] object
an object containing host and any other properties sent in the array object.
Note: This object is only appended when using triggered mode and an array for input payload. It is intended for advanced users and permits scenarios where you need additional properties to be tagged into your result for use downstream.
Details
Returns false if no response received, or if the host is unresolveable.
Default monitor is every 20 seconds but can be configured.
Protocol...
  • Automatic
    Will use any Protocol, IPv4 or IPv6, to reach host; based on your operating system network settings
  • IPv4
    Forces use of IPv4 to reach host. Will fail if no route availibe
  • IPv6
    Forces use of IPv6 to reach host. Will fail if no route availibe
Mode...
  • Timed
    In Timed mode, the fields Target and monitor (S) must be populated.
    Target must be a CSV list of hosts / IPs e.g. "192.168.0.1" or "192.168.0.1, www.google.com"
    monitor (S) is the number of seconds between monitors
  • Triggered
    In Triggered mode, you must connect an input wire and pass a msg in to trigger the monitor operation.
    If Target is populated, this will be used as the host/ip. The Target must be is a CSV list of hosts / IPs e.g. "192.168.0.1" or "192.168.0.1, www.google.com"
    If Target is left empty, you can pass a CSV string or an array of hosts in msg.payload.
    • string - a CSV list of hosts / IPs e.g. "192.168.0.1" or "192.168.0.1, www.google.com"
    • array - an array of hosts as strings or objects. Note: The object must contain at minimum .host. Optionally, you can add a timeout property between 1000 & 30000 (default is 5000 / 5 seconds). Additionally, you can add whatever other properties you wish to this object and when the monitor result is returned, it will be passed to the next node in msg.monitor for use downstream
    • Example array payload input:
          "192.168.0.99",
              "host":"192.168.0.1",
              "name":"The router"
              "host":"myapiserver.com",
              "name":"external API",
              "timeout": 20000,
              "support":"[email protected]"
Version: 1.1.9
Updated 2 years, 1 month ago
License: CC0-1.0
6 in the last week
  • echar-checkdev
  • weidmueller
  • UC20
  • weidmuller
  • echar
