doc-red 1.6.2
A plugin for Node-RED which helps to documentate and enhance your workspace.
npm install doc-red
doc-RED
A Node-RED plugin to help you managing your flow creation and documentation.
This plugin enhance the Node-RED documentation feature with those features:
  • adds a documentation-tab to keep an overview for your documentations as well as your todo lists
  • if activated in the tab options adds icons and/or tooltips to your nodes which shows:
    • the nodes documentation
    • shows the input / output names
    • a dummy documentation to get easier access to the node documentation or to see the node id
    • the node todos (as a separat icon / tooltip)
General
You can use the node-red documentation section which has every tab, group, subflow or node.
Everything you write there will be counted as normal documentation, with three exceptions:
"# Inputs", "# Outputs" and "# Todo" will be handled different and will always be shown above your documentation in the tooltip (no matter where you write them).
Input and Output
If you want to quickly see the names of your input and outputs you can add an "# Input" (or "# Inputs") or an "# Output" (or "# Outputs") header into your documentation.
If you want also some detailed text for an output you can add a subheader like "## Outputname" and write some text to it.
# Output
This is a docu to the three outputs, but only the special and the error output are documentated...
## special
This special output would be much more important if the flow would go on!
## error
Well, this is unfortunate...
Set output names
Outputs
Create a Todo list
Use the node red documentation in a tab, group, subflow or node.
Add a "# Todo" headline and write your text what should be done. This info will be shown in the documentation tab.
Tip: You can use markdown to create a list with things that must be done.
# Todo
- [ ] step 1
- [ ] step 2
- [x] already done step 3
- [ ] step 4
How to add todos
If you use a subflow you can add a todo list either on the node self or in the subflow description. The description on the node will be used if both has a todo description.
Icons
(1) If a node has a todo list a small pencil icon will be added. If the todos are completed, the icon will became light grey. (2) If a node has a documentation a small document icon will be added. If the documentation is purely automatic (#Inputs and or #Outputs) it will became light grey. (3) If a node has a documentation and a todo list it has both icons. This color of the icons in the picture is black, as the todo list is not completed and it has a documentation written.
icons
Hovering on the icons will get you the text (either todos or documentation with Inputs and Output texts)
tooltip
Documentation tab
If you want to have an overview on your documentations as well as your open tasks use the documentation tab.
It lists all nodes by the order subflow -> subflow nodes, flow -> groups -> nodes. If you hover the node you also get a search icon to find the position of the node and an shortcut to edit the nodes documentation.
You can also search for any text you see in the tab.
If your todo has a completed list, it will still be added but with grey text and a (done) suffix.
The documentation tap also has a settings menu. Here you can hide the tooltips or the icons on the workspace or show only todos in your documentation tab.
Settings
Subflows
You can show / hide the whole main subflow documentation on your subflow nodes in the workspace. It will currently either show everything (TODO, documentation, input, outputs) from the main subflow node or nothing. If the workspace node has it's own section, this will always be shown instead of the main subflow documentation. This option can be changed in the settings.
Gitpod and example json
A ready to launch gitpod setting is available. Just start it, wait till your workspace is ready and start "node-red examples/todo.json".
This repository and the code inside it is licensed under the MIT License. Read LICENSE for more information.
Version: 1.6.2
Updated 7 months ago
Rating: 5.0 5
15 in the last week
  • documentation
  • documentate
  • doc
  • do
  • todo
  • todo list
  • Sebastian Meier
  • Christian Geiger
