cosmino-digitaltwin-add-quantity 0.0.1
A Cosmino Node-RED custom node for adding quantity.
npm install cosmino-digitaltwin-add-quantity
CosminoAG DigitalTwin Add Quantity Node
This npm package provides a convenient way to add quantity produced of a workcenter in the Cosmino AG DigitalTwin Simulation system. It simplifies the process of adding quanity with type produced/rework/scrap, allowing users to easily integrate this functionality into their Node-red applications. Configuration parameter's UID, qunatity and Type is required. UID and quanity can be empty and the type can be undefined if passed from external nodes like this way msg.payload = { "type":"produced","quantity":15, "uid": "ID12"}
Parameters passed from external nodes will be overwritten by config parameter.
To install the package, use npm:
To use this package, follow these steps:
The uid parameter is the unique identifier of the workcenter, the Type parameter is the type of quatity to update and the qunatity is the amount to be updated.
Parameters passed from external nodes will be overwritten by the configuration parameters. Make config parameters Type "undefined" if passed from external nodes. If you want to use external parameters, you can pass them through the msg.payload object like this:
msg.payload = {
    "type":"produced",
    "quantity":15,
    "uid": "ID12"
Configuration Options
  • UID (required): The unique identifier of the workcenter.
  • Type (required): The type of quanity to update.
  • Quantity (required): The amount of quanity to update.
Contributing
Contributions are welcome! If you have any suggestions, bug reports, or feature requests, please open an issue or submit a pull request on the GitHub repository.
This package is licensed under the MIT License. Feel free to use, modify, and distribute it as per the terms of this license.
Version: 0.0.1
Updated 3 years, 7 months ago
1 in the last week
  • cosmino-digitaltwin-add-quantity
  • dashboard
  • cosmino
  • custom node
  • quantity add
