connect-nodes 0.0.6
Node-RED contribution package with nodes for interaction with CONNECT Smart Home system and configure your own UI
npm install connect-nodes
connect-nodes
CONNECT Smart Home nodes pack
Node-RED contribution package with nodes for interaction with CONNECT Smart Home system and configure your own UI.
Full documentation and automation examples: CONNECT Docs.
Follow us on Instagram, YouTube.
Nodes description
UI nodes:
UI nodes provide to customize your own UI. Easily control any your devices connected via Node-RED with UI nodes.
  • You can download free mobile apps to use your UI:
iOSAndroid
  • Or try our DEMO WEB UI (Login: demo, Password: demo).
UI-Switch
Node for provide a switch in the WEB UI or App.
UI-Dimmer
Node for provide one-channel dimmer in the WEB UI or App.
UI-CW
Node for provide two-channel Cold-Warm dimmer in the WEB UI or App.
UI-RGB
Node for provide three-channel RGB dimmer in the WEB UI or App.
UI-RGBW
Node for provide four-channel RGBW dimmer in the WEB UI or App.
UI-Thermostat
Node for provide thermostat control in the WEB UI or App.
UI-Status
Node for visualize any data in the WEB UI or App.
UI-Curtains
Node for provide curtains, blinds etc. control in the WEB UI or App.
UI-Notification
Node for quick notification / push-message in the WEB UI or App.
UI-Scene
Node for adding Scene button in the App.
Functional nodes:
Digital-In
Node for get value of digital input of CONNECT blocks. Currently supported blocks:
  • DI4 - Digital inputs (dry contact type)
  • DI4 OC - Digital inputs (open collector or open drain types)
Relay-Out
Node for control digital output of CONNECT blocks. Currently supported blocks:
  • R1 - Relay block with double-throw (NC, NO) relay
  • R8 - Relay block with single-throw (NO) relays
Dimmer-Out
Node for control dimmable outputs of CONNECT blocks. Currently supported blocks:
  • DT1 - Triac 230V dimmer
  • W4 - 4-channel (RGB / RGBW / Cold Warm) LED strips controller
RS485-In
Node for reading RS485 messages from any RS485 devices. Currently supported blocks:
  • RS485 - Block providing connection of third-part RS485 devices to CONNECT Smart Home system
RS485-Out
Node for sending RS485 messages from CONNECT Smart Home system to any RS485 devices. Currently supported blocks:
ModbusRTU
Node for sending Modbus RTU requests from CONNECT Smart Home system to any Modbus RTU devices. Function codes currently supported include:
  • FC 1: Read Coil Status
  • FC 2: Read Input Status
  • FC 3: Read Holding Registers
  • FC 4: Read Input Registers
  • FC 5: Force Single Coil
  • FC 6: Force Single Register
  • FC 15: Force Multiple Coils
  • FC 16: Force Multiple Registers
DMX
Node for interaction CONNECT Smart Home with DMX512 devices. Currently supported blocks:
  • DMX - Block providing connection of DMX devices to CONNECT Smart Home system
Ajax
Node for receiving statuses from Ajax sensors that was paired with CONNECT blocks. Currently supported blocks:
  • Y1 Controller - The compact CONNECT Smart Home system controller
Ajax-Add
Node for pairing Ajax sensors in CONNECT Smart Home. Currently supported blocks:
Ajax-Delete
Node for remove all Ajax sensors that was paired with CONNECT blocks. Currently supported blocks:
ZigBee
Node for sending & receiving data to/from Zigbee sensors and other devices that was paired with CONNECT Smart Home system. Currently supported blocks:
ZigBee-Add
Node for pairing ZigBee devices in CONNECT Smart Home. Currently supported blocks:
ZigBee-Delete
Node for remove all ZigBee devices that was paired with CONNECT. Currently supported blocks:
or install it via Node-RED Manage palete
Authors
CONNECT Smart Home
Version: 0.0.6
Updated 2 years, 10 months ago
Rating: 5.0 24
5 in the last week
  • CONNECT digital input
  • CONNECT relay
  • CONNECT RS485 in
  • CONNECT RS485 out
  • CONNECT DMX
  • CONNECT dimmer
  • CONNECT DMX mode config
  • CONNECT DMX sending period config
  • CONNECT modbus RS485
  • CONNECT Ajax
  • CONNECT Ajax add
  • CONNECT Ajax delete
  • CONNECT Ajax protection
  • CONNECT ZigBee
  • CONNECT ZigBee add
  • CONNECT ZigBee delete
  • CONNECT UI switch
  • CONNECT UI dimmer
  • CONNECT UI rgb
  • CONNECT UI rgbw
  • CONNECT UI warm cold
  • CONNECT UI thermostat
  • CONNECT UI status
  • CONNECT UI curtains
  • CONNECT UI notification
  • CONNECT UI scene
  • CONNECT UI room config
  • CONNECT UI category config
  • connect-smart-home
  • connect
  • iot
  • smarthome
  • smart
  • home
  • homekit
  • dmx
  • 1-wire
  • modbus
  • rs485
  • dimmer
  • rgbw
  • rgb
  • led
  • ajax
  • zigbee
  • 0-10v
