connect-logic-nodes 0.0.3
Node-RED contribution package with nodes to simplify configuration of logic for CONNECT Smart Home.
npm install connect-logic-nodes
connect-logic-nodes
logo CONNECT Logic nodes pack
Full documentation and automation examples: CONNECT Docs.
Follow us on Instagram, YouTube.
Nodes description
Logic-invert
Node for invert input logical value.
Logic-variable-set
Node for set the variable value to the memory.
Logic-variable-get
Node for get the variable value from the memory.
Logic-variable-condition
Node for check the condition for current value of the variable.
Logic-button-events
Node for generate button events. Button events currently supported include:
  • Single click
  • Double click
  • Triple click
  • Quadre click
  • Hold started
  • Hold finished
You can also get total number of clicks.
Logic-toggle
Node for toggle state.
Logic-constant
Node for inject constant value.
or install it via Node-RED Manage palete
Authors
CONNECT Smart Home
Version: 0.0.3
Updated 3 years, 2 months ago
Rating: 5.0 14
11 in the last week
  • Connect-logic-invert
  • Connect-logic-variable-config
  • Connect-logic-variable-set
  • Connect-logic-variable-get
  • Connect-logic-variable-condition
  • Connect-logic-button-events
  • Connect-logic-toggle
  • Connect-logic-constant
  • Connect-logic-smooth-change
  • connect-smart-home
  • connect
  • iot
  • smarthome
  • smart
  • home
  • boolean
  • logic
  • invert
  • variable
  • condition
  • button
  • events
  • buttonevents
  • singleclick
  • doubleclick
  • tripleclick
  • quadreclick
  • toggle
  • constant
  • smooth
