axonize-node-red-contrib-azure-event-hub-send-message 0.1.1
Send messages to the azure event hub
npm install axonize-node-red-contrib-azure-event-hub-send-message
This custom node-red node is used to send messages to the Azure Event Hub.
Input Parameters
Name (Optional)
The name parameter takes a string as input. The string would appear as the name of the node. Default Value is: Axonize - Send - Azure Event Hub
Connection String (Mandatory):
The endpoint connection string which allows you to connect to the event hub. Format: Endpoint=sb://XXXXXXXXX-prd.servicebus.windows.net/;SharedAccessKeyName=XXXX;SharedAccessKey=XXXXX
Event Hub path (Mandatory):
The name of the event hub where the messages have to be sent to.
npm i axonize-node-red-contrib-azure-event-hub-send-message
  1. Copy the below JSON
[{"id":"864e40f6.22f76","type":"tab","label":"Azure Event Hub Send Message","disabled":false,"info":""},{"id":"22085b05.857334","type":"inject","z":"864e40f6.22f76","name":"Send Payload","topic":"","payload":"{\"data\": \"{temperature: 95, wind: 10}\" }","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":"","x":190,"y":300,"wires":[["27a034a5.375acc"]]},{"id":"3110b8b3.46b708","type":"debug","z":"864e40f6.22f76","name":"","active":true,"console":"false","complete":"true","x":802.000054359436,"y":299.9299564361572,"wires":[]},{"id":"27a034a5.375acc","type":"axonizeSendAzureEventHubMessages","z":"864e40f6.22f76","name":"Axonize - Send - Azure Event Hub","x":520,"y":320,"wires":[["3110b8b3.46b708"]]}]
  1. Access the node-red UI using http://localhost:1880. Click on Import-->Clipboard and paste the copied json in the text area and Click Import.
  2. Update the Name, Connection String and Event Hub path parameters with the ones you wish to send messages to.
Version: 0.1.1
Updated 5 years, 9 months ago
2 in the last week
  • axonizeSendAzureEventHubMessages
  • Clovity
  • Azure
  • EventHub
  • SendEvents
