autana-testing-call-or-mock 1.0.6
Node-RED node for call or mock
npm install autana-testing-call-or-mock
Information
Calls a flow that starts with a named link in node and finish with a link out node configured in 'return' mode, and passes on the response. (a function flow)
Inputs
targetstring
The name of the link in node to call on normal/runtime execution mode.
To enable the test execution mode (Unit Tests), You must set the Global.runtime_profile variable to "TEST".
If test execution mode is enabled, the suffix .mock is added to target before to perform the call.
Details
The target link in node can be placed on any tab.
When this node receives a message, it is passed to the connected target link in node.
It then waits for a response which it then sends on.
If no response is received within the configured timeout, default 30 seconds, the node will log an error that can be caught using the catch node.
  • If there is a link in node with target name, it will be called
  • If there are two or more link in nodes with the same target name, an error will be raised
  • The link call cannot call a target link in node inside a subflow
Version: 1.0.6
Updated 3 years, 9 months ago
3 in the last week
  • node-red-nodegen
  • testing
  • test
  • mock
  • mocking
  • call
