autana-api-gateway 1.0.3
A minimalist API-Gateway for Node-RED
npm install autana-api-gateway
autana-api-gateway
Information
Before use API Gateway, first configure the rules sending a msg.payload with a JSON like this:
   "GET": {
      "/pets/": {
         "actionId": "read all pets"
      "/pets/:petId": {
         "actionId": "read pet"
   "POST": {
      "/pets/": {
         "actionId": "create pet"
      "/pets/:petId": {
         "actionId": "update pet"
   "DELETE": {
      "/pets/:petId": {
         "actionId": "delete pet"
The output msg.req contains an autana object like this:
msg.req.autana =
   "method": "POST",
   "route": "/pets/:petId",
   "url": "/pets/123",
   "pathParams": {
      "petId": "123"
   "queryParams": {},
   "action": {
Then You can take an action filtering by msg.req.autana.action.actionId
exampleFlow
actionId filtering
Remarks
In your main flow, you must connect a http response node as the end of your flow.
Extension
You can add more information to the action when configuring:
Example: Add anActionField, anotherActionField and persistence to the action "read all pets"
   "GET": {
      "/pets/": {
         "actionId": "read all pets",
         "anActionField": "foo",
         "anotherActionField": "bar",
         "persistence": {
            "table": "dbo.pets"
      "/pets/:petId": {
When receiving a GET to /pets/, msg.req.autana.action will contain this:
   "persistence": {
      "table": "dbo.pets"
Version: 1.0.3
Updated 3 years, 8 months ago
4 in the last week
  • autana
  • rest
  • api
  • apigateway
  • http
  • json
  • jsonata
