atem-connection-nodered 0.2.1
This package provides an interface between BlackMagic ATEM switchers and NodeRed
npm install atem-connection-nodered
ATEM Connection for NodeRed
This package provides an interface between BlackMagic ATEM switchers and NodeRed using the ATEM Connection project by Norsk rikskringkasting (NRK). This project is a continuation of the BlackMagic ATEM NodeRed project as i can no longer support the ATEM side of the project.
What's Supported?
Input messages
Below is a list of messages that can be sent to the node:
Action
Will call a function to action something on the atem
        topic: "previewInput", //The function to call
        payload: {
            // The payload to send (see the function for information on this)
Direct action
Will call a method directly implemented by ATEM Connection. Be careful using as this can be problematic, but it is very powerful if used correctly!
//Example setting upstream keyer 1 on me 0 on air
//https://nrkno.github.io/sofie-atem-connection/classes/Atem.html#setUpstreamKeyerOnAir
        topic: "directAction",
        payload: {
            function: "setUpstreamKeyerOnAir",
            parameters: [true, 0, 1]
Output messages
Below is a list of messages that can be sent out by the node:
Connection State
        topic: "connection",
        payload: "connected/disconnected"
Info / Error / Debug / Command
        topic: "info/error/debug/command",
        payload: "" //The message
State Changed
        topic: "stateChanged",
        payload: {
            state: {} //The state object
            pathToChange: "" //The path
Responses
        topic: "response",
        success: true/false,
        state: {
            //The ATEM state
        payload: {
            //The response
Function Changed Example
This message is what is output when a function is supported by this project and has been translated. See the specific supported functions below.
    topic: "function",
    payload: {
        function: "previewInput",
        data: {
            ME: {
                //The ME
            input: {
                //The input that was selected
        state: {
            // The state object
        pathToChange: "video.mixEffects.1.previewInput" // Where the change came from specifically
Thanks
ATEM Connection project by Norsk rikskringkasting (NRK) which provides the connection to the ATEM.
Aims!
Here is a list of things i want to add:
autoDownstreamKey
setDownstreamKeyCutSource
setDownstreamKeyFillSource
setDownstreamKeyOnAir
autoTransition
cut
fadeToBlack
setTransitionPosition
setTransitionStyle
macroRun ✅
macroContinue ✅
macroStop ✅
changePreviewInput ✅
changeProgramInput ✅
setAuxSource
setUpstreamKeyerCutSource
setUpstreamKeyerFillSource
startRecording
startStreaming
stopRecording
stopStreaming
Version: 0.2.1
Updated 4 years ago
2 in the last week
  • atem-connection-connection
  • atem-connection-atem
  • blackmagic
  • black
  • magic
  • ATEM
