@wago/node-red-wdx-trend 11.0.0
WAGO - Node RED - WDX Trend
npm install @wago/node-red-wdx-trend
Wago - Node Red - WDX - Trend
Node Red plugin WDX Trend Palette with nodes implementing WDX WS Trend Interface communication within Node Red application.
Table of Contents
Requirements
  • WDX Runtime - Docker or local WDX runtime installation.
  • Node-RED editor.
Node RED Palette Management Installation
Open your Node-RED installation UI palette management and search for package @wago/node-red-wdx-palette.
image info
Node RED Manual Package installation
Navigate your console to the Node-RED data directory:
cd ~/.node-red/data # Directory would differ based on your Node-RED installation
Install the library, using npm or yarn:
or
yarn add @wago/node-red-wdx-trend
To use WDX nodes in your Node-RED flow, follow these steps:
  1. Install the @wago/node-red-wdx-trend package in your Node-RED project.
  2. Import the required nodes into your flow and configure the necessary WDX WS Client options.
WDX Nodes - WS Client Configuration
Examples
For more examples see example project.
This library is licensed under the MIT License. See the LICENSE.md file for more details.
c) 2024 Elrest Automations Systeme GMBH
This README.md provides a clear introduction to the TypeScript model schema library, with examples of how to use it, and includes the required copyright and licensing information under the MIT License.
Version: 11.0.0
Updated 1 year, 7 months ago
7 in the last week
  • wago
  • wdx
  • trend
  • IoT
  • palette
  • plc
  • codesys
  • automation
  • Pavol Fazik
  • Slavomir Sidor
