@wago/node-red-wdx-alarm 13.0.0
WAGO - Node RED - WDX Alarm
npm install @wago/node-red-wdx-alarm
Wago - Node Red - WDX - Alarm
Node Red plugin WDX Palette with nodes implementing WDX WS Interface communication within Node Red application.
Table of Contents
Requirements
  • WDX Runtime - Docker or local WDX runtime installation.
  • Node-RED editor.
  • Node-RED WDX Pallete.
Node RED Palette Management Installation
Open your Node-RED installation UI palette management and search for package @wago/node-red-wdx-palette.
image info
Node RED Manual Package installation
Navigate your console to the Node-RED data directory:
cd ~/.node-red/data # Directory would differ based on your Node-RED installation
Install the library, using npm or yarn:
or
yarn add @wago/node-red-wdx-alarm
To use WDX nodes in your Node-RED flow, follow these steps:
  1. Install the @wago/node-red-wdx-palette package in your Node-RED project.
  2. Import the required nodes into your flow and configure the necessary WDX WS Client options.
WDX Nodes - WS Client Configuration
Examples
For more examples see example project.
This library is licensed under the MIT License. See the LICENSE.md file for more details.
© 2024 Elrest Automations Systeme GMBH
This README.md provides a clear introduction to the TypeScript model schema library, with examples of how to use it, and includes the required copyright and licensing information under the MIT License.
Version: 13.0.0
Updated 1 year, 4 months ago
5 in the last week
  • wago.wdx.alarm.list
  • wago.wdx.alarm.list-active
  • wago.wdx.alarm.list-history
  • wago.wdx.alarm.confirm
  • wago.wdx.alarm.confirm-all
  • wago.wdx.alarm.monitor
  • wago.wdx.alarm.detail
  • wago.wdx.alarm.delete
  • wago.wdx.alarm.save
  • wago.wdx.alarm.get-status
  • wago.wdx.alarm.set-active
  • wago.wdx.alarm.set-inactive
  • wago
  • wdx
  • alarm
  • palette
  • plc
  • codesys
  • automation
  • Pavol Fazik
  • Slavomir Sidor
