@wago/node-red-io-api 1.0.4
A set of nodes to interact directly with WAGO PFC controllers I/O bus. Controller should be runnung the open source wago-kbus-api
npm install @wago/node-red-io-api
 @wago/node-red-api-io
A set of nodes to control open source MQTT IO Module API on WAGO Linux PFC Controllers.
  • Nodes connect directly to MQTT broker either onboard the controller or externally
  • Status and error messages are caught by the kbus reader
  • Integrated scaling for analog input signals and process scaling for analog outputs
  • New cyclic oprtation to prevent stagnant data
  • Very low CPU resource usage
Get started
You must install the driver on your controller. The installer can be found here pfc-kbus-api, take care to update the kbus-api.conf file on the controller as this determines the broker and behavior of the kbus-api.
Default MQTT Broker is 127.0.0.1 and NodeID is "PFC200" unless changed in configuration file.
Requirements
@wago/node-red-io-api is under the MIT license. See the LICENSE for more information.
Links
Version: 1.0.4
Updated 4 years, 2 months ago
Rating: 3.0 2
12 in the last week
  • kbus in
  • kbus out
  • digital input
  • digital output
  • analog input
  • temperature sensor
  • analog output
  • power measurement
  • wago
  • kbus
  • plc
  • codesys
  • automation
