@theotherwillembotha/node-red-whatsapp 0.4.6
Node-RED nodes for WhatsApp messaging via the Baileys library.
npm install @theotherwillembotha/node-red-whatsapp
Node-RED nodes for WhatsApp messaging via the Baileys library. Supports sending and receiving messages to/from WhatsApp groups and individual contacts, with persistent session management and per-message-type filtering.
[!WARNING] This package is in early development. Many features may be incomplete, unstable, or behave unexpectedly. A significant amount of diagnostic information is currently printed to the Node-RED console — this is intentional while the package matures and will be reduced in future releases. Use with caution in production environments.
Prerequisites
  • Node.js >= 18
  • Node-RED >= 4.0.0
  • A WhatsApp account that can be linked via QR code (WhatsApp Web / Linked Devices)
Either use the Manage Palette option in the Node-RED editor, or run the following in your Node-RED user directory (typically ~/.node-red):
Example flow using the WhatsApp nodes
WhatsApp Account (config node)
Manages a WhatsApp Web session. Handles QR-code pairing and persists session credentials to disk so the connection survives Node-RED restarts.
WhatsApp Account config node
Property Description
name Display label for this account
Linking an account — open the node editor and click Link Account. A QR code is displayed; scan it with WhatsApp on your phone (Linked Devices). Once scanned, the session is saved and reconnected automatically on each restart. To unlink, click Unlink Account and remove the linked device from WhatsApp on your phone.
Claiming an existing account — if a WhatsApp session was linked outside of a config node (e.g. from a previous deployment), unclaimed accounts appear in a dropdown. Select one and click Claim to adopt it.
WhatsApp Group (config node)
References a WhatsApp group within a linked account. Used as the target for Send Message nodes and the source for Receive Message nodes.
WhatsApp Group config node
name Display label for this config node
account The WhatsApp Account config node that owns this group
group The WhatsApp group to use — populated from groups available on the selected account
Click Create New Group to create a new WhatsApp group directly from Node-RED. The group members list allows adding, removing, and promoting/demoting participants.
WhatsApp Send Message
Sends a message to a WhatsApp group when triggered by an incoming Node-RED message.
WhatsApp Send Message node
name Display label
group The WhatsApp Group config node to send to
Messages — each row in the messages list is sent as a separate WhatsApp message. Supported types:
Type Value sources
Text msg, flow, global, str
Image msg, flow, global
Video msg, flow, global
Document msg, flow, global (with optional filename and MIME type)
The node resolves each field's value against the incoming message (for msg type) or from context, then sends to the group.
WhatsApp Dynamic Send Message
Sends one or more WhatsApp messages to a recipient resolved at runtime — for example, replying directly to the sender of a group message.
name Display label
account The WhatsApp Account config node to send from
recipient The target JID, resolved from msg, flow, global, or a static string. Defaults to msg.payload.sender.id
If the recipient JID ends with @lid (newer WhatsApp addressing), the node automatically resolves it to the corresponding phone-number JID via the contact store before sending.
The messages list supports the same types as Send Message (Text, Image, Video, Document).
WhatsApp Receive Message
Outputs a Node-RED message for each incoming WhatsApp message in a group.
WhatsApp Receive Message node
name Display label
group The WhatsApp Group config node to listen on
own messages Whether to forward messages sent by this account
output path Where in the output msg to place the WhatsApp message (or which flow/global context variable to write to)
Accept filters — each message type can be individually enabled or disabled. Enabled by default: Text, Extended Text, Image, Video, Album. Available types: Text, Extended Text, Image, Video, Album, Document, Contact, Template, Location, Event, Event Response, Sticker.
Output message — the WhatsApp message object is placed at the configured output path (default: msg.payload). The object includes:
Field Description
messageId WhatsApp message ID
timestamp Unix timestamp (seconds)
chat.id Group JID
chat.name Group display name
sender.id Sender JID
sender.name Sender display name
sender.me true if sent by this account
type Message type (e.g. Text, Image, Location)
payload Type-specific content (text, image buffer, coordinates, etc.)
Data storage
Session credentials and the SQLite message store are written to /data/whatsapp/ if the /data directory exists (standard Node-RED Docker image), otherwise to ./whatsapp/ relative to the Node-RED working directory.
Part of the node-red-plugincore ecosystem
Package Description
node-red-plugincore Core framework
node-red-telemetry Structured logging flow node
node-red-loki Grafana Loki log transport
node-red-prometheus Prometheus metrics provider
node-red-circuitbreaker Circuit breaker fault tolerance
node-red-zookeeper Apache ZooKeeper integration
node-red-reolink Reolink camera integration
node-red-temporal Temporal.io workflow integration
node-red-whatsapp WhatsApp messaging (this package)
ISC
Version: 0.4.6
Updated 1 month, 1 week ago
25 in the last week
  • DelegatedConfigReferenceNode
  • WhatsappAccountConfigNode
  • WhatsappGroupConfigNode
  • WhatsappSendMessageNode
  • WhatsappDynamicSendMessageNode
  • WhatsappReceiveMessageNode
  • whatsapp
  • baileys
  • messaging
  • chat
