@theotherwillembotha/node-red-temporal 0.4.6
Time value manipulation nodes for Node-RED. Built on @theotherwillembotha/node-red-plugincore.
npm install @theotherwillembotha/node-red-temporal
node-red-temporal
Date and time manipulation nodes for Node-RED. Parse, convert, adjust, and compute durations between date/time values - built on the TC39 Temporal API via temporal-polyfill.
Requirements: Node.js ≥ 18, Node-RED ≥ 4.0.0
  • Read date/time values from msg, flow, global context, or the current timestamp
  • Parse all common formats - ISO 8601, Unix timestamps, RFC 2822, JavaScript Date objects, and custom Moment.js-style format strings
  • Timezone-aware conversion using IANA timezone names (Europe/Amsterdam) or UTC offsets (+02:00)
  • Optional time adjustment with a compact expression syntax (+1y -2M +3d)
  • Compute durations between two timestamps in multiple output formats
  • Interval measurement mode - automatically tracks the gap between consecutive messages
Or search for node-red-temporal in the Node-RED palette manager.
Table of Contents
  1. Temporal Transform
  2. Temporal Duration
  3. Format reference
  4. Custom format strings
  5. Adjustment string syntax
  6. Timezone reference
  7. Error handling
  8. Examples
Temporal Transform
Transforms a date/time value from one representation to another in a single node.
Temporal Transform editor
Input
Field Description
From Where to read the date/time value. Supports msg, flow, and global properties, or timestamp (now) to capture the current time when the message arrives.
Format How the input value is encoded. Choose a named preset or enter a custom format string. Can also be read dynamically from a msg, flow, or global property.
Timezone The timezone the input value is expressed in. Required for formats that carry no timezone information (date, datetime, unix-s, unix-ms, rfc2822, and custom formats). Accepts IANA names or UTC offset strings. Can also be read from a property.
When From is set to timestamp (now), Format is locked to milliseconds since epoch and Timezone has no effect.
Modification
Field Description
Adjust by An optional expression that shifts the time value before output. Leave empty to pass through unchanged. A live preview below the field describes the adjustment in plain English - invalid expressions are highlighted in red. See Adjustment string syntax.
Output
Field Description
To Where to write the result. Supports msg, flow, and global properties.
Format How to encode the output value. Choose a named preset or enter a custom format string. Can also be read dynamically from a property.
Timezone The timezone to express the output value in. Accepts IANA names or UTC offset strings.
Temporal Duration
Computes the duration between two date/time values.
Temporal Duration editor
From Time / To Time
Each endpoint has the same three fields:
Field Description
From / To Where to read the date/time value. Supports msg, flow, and global properties, timestamp (now) to use the current time, or previous message (From only - see below).
Format How the value is encoded. Choose a named preset or a custom format string. Hidden when timestamp (now) or previous message is selected.
Timezone The IANA timezone or UTC offset the value is expressed in. Required for formats that carry no timezone information.
The duration is always computed as To − From (positive when To is later than From).
Interval measurement - "previous message" mode
When From is set to previous message:
  • The first message stores the To time as a baseline and is not forwarded.
  • Every subsequent message computes the duration from the stored baseline to the current To time, writes the output, then stores the current To time as the new baseline.
  • The stored baseline resets when the flow is redeployed.
This mode is useful for measuring the interval between recurring messages - sensor readings, heartbeats, pipeline throughput.
Offset
Field Description
Offset by An optional expression that shifts the computed duration before output. Uses the same syntax as the Temporal Transform Adjust by field. Leave empty for no adjustment.
Output
Field Description
Mode How to express the duration. See output modes below.
Output modes
Mode Output type Description
Total in unit number The entire duration as a single numeric value in the selected unit (milliseconds, seconds, minutes, hours, or days). Fractional values are returned where applicable.
Duration components object A plain object with keys years, months, weeks, days, hours, minutes, seconds, milliseconds. Values are broken down from the selected Largest unit downward - fields for larger units are always zero.
ISO 8601 string string The duration as an ISO 8601 duration string, e.g. P1Y2M3DT4H5M6S.
Human readable string A locale-formatted string using Intl.DurationFormat with English locale and the selected style.
Human readable styles
Style Example
Long 2 hours, 30 minutes, 5 seconds
Short 2 hr., 30 min., 5 sec.
Narrow 2h 30m 5s
Format reference
The following named presets are available in both nodes:
Preset Description Example
iso ISO 8601 with timezone offset 2024-05-16T14:30:00+02:00
iso-utc ISO 8601 UTC (Zulu) 2024-05-16T12:30:00.000Z
date Date only 2024-05-16
datetime Date and local time (no timezone) 2024-05-16 14:30:00
unix-s Seconds since epoch 1715860200
unix-ms Milliseconds since epoch 1715860200000
js-date JavaScript Date object (Node.js Date instance)
rfc2822 RFC 2822 email date format Thu, 16 May 2024 14:30:00 +0200
Select custom to enter a format string using Moment.js-style tokens. Tokens are case-sensitive and matched longest-first.
Token Description Example Token Description Example
YYYY Year (4-digit) 2024 hh Hour 12 h, padded 02
YY Year (2-digit) 24 h Hour 12 h 2
MM Month, padded 05 mm Minute, padded 30
M Month 5 m Minute 30
DD Day, padded 06 ss Second, padded 05
D Day 6 s Second 5
HH Hour 24 h, padded 14 SSS Milliseconds 047
H Hour 24 h 14 A / a AM/PM or am/pm PM
Any character that does not match a token is treated as a literal separator (e.g. -, /, , :).
Examples
Format string Output
YYYY-MM-DD 2024-05-16
DD/MM/YYYY 16/05/2024
DD/MM/YYYY HH:mm:ss 16/05/2024 14:30:05
YYYY-MM-DD HH:mm:ss.SSS 2024-05-16 14:30:05.047
hh:mm:ss A 02:30:05 PM
YYYY-MM-DDTHH:mm:ss 2024-05-16T14:30:05
Named month abbreviations (e.g. Jan, Feb) are not supported - the format system works with numeric values only.
The Adjust by field (Temporal Transform) and Offset by field (Temporal Duration) accept the same compact expression syntax.
Units
Token Unit Token Unit
y Years (calendar) H Hours
M Months (calendar) m Minutes
w Weeks (= 7 days) s Seconds
d Days S Milliseconds
Tokens are case-sensitive: M is months, m is minutes; H is hours, S is milliseconds.
Syntax rules
  • Prefix each group with + (add) or - (subtract).
  • A sign applies to all units that follow it until the next sign: -1H30m subtracts both 1 hour and 30 minutes.
  • Multiple groups can be combined freely: +1y -2M +3d
  • Whitespace is ignored: +1y -2M and +1y-2M are equivalent.
  • The same unit may appear multiple times - values are accumulated: +1H +1H equals +2H.
  • An empty string means no adjustment - the value passes through unchanged.
Examples
String Effect
+1y Add 1 year
-30m Subtract 30 minutes
+1y4d Add 1 year and 4 days
+1y4d-40m+20m Add 1 year, add 4 days, subtract net 20 minutes
+1M -1d Add 1 month, subtract 1 day
-1H30m Subtract 1 hour and 30 minutes
+500S Add 500 milliseconds
+1w3d Add 10 days (1 week + 3 days)
Calendar unit behaviour
Calendar units (y and M) operate on the calendar date, not a fixed duration. The result is clamped to the last valid day of the month where necessary:
  • Adding 1 month to 2024-01-31 → 2024-02-29 (leap year end of February)
  • Adding 1 year to 2024-02-29 → 2025-02-28 (non-leap year)
Timezone reference
Timezone fields accept:
  • IANA timezone names - e.g. Europe/Amsterdam, America/New_York, Asia/Tokyo, UTC
  • UTC offset strings - e.g. +02:00, -05:30, +00:00
An autocomplete dropdown is available in the editor for IANA names. The full list is sourced from the server's Intl.supportedValuesOf('timeZone').
Error handling
If a date/time value cannot be parsed, or if an adjustment/offset expression is invalid:
  • The message is dropped (not forwarded to the output).
  • A warning is logged on the node, visible in the Node-RED debug panel.
Downstream nodes only receive messages that were processed successfully.
Examples
Convert a Unix timestamp to a human-readable local time
Field Value
From msg.payload - milliseconds since epoch
Timezone UTC
To msg.payload
Output Format YYYY-MM-DD HH:mm:ss (custom)
Output Timezone Europe/Amsterdam
1715860200000 → 2024-05-16 14:30:00
Add a 5-day offset and output ISO UTC
Field Value
From msg.payload - ISO 8601 with offset
Adjust by +5d
Output Format iso-utc
2024-05-16T14:30:00+02:00 → 2024-05-21T12:30:00.000Z
Capture the current time in a local timezone
Field Value
From timestamp (now)
To msg.timestamp
Output Timezone Africa/Johannesburg
Writes the current local time in Johannesburg to msg.timestamp.
Compute the total seconds between two timestamps
Field Value
From msg.start - milliseconds since epoch, timezone UTC
To msg.end - milliseconds since epoch, timezone UTC
Mode Total in unit - Seconds
Output To msg.payload
Measure the interval between messages
Field Value
From previous message
To msg.payload - milliseconds since epoch, timezone UTC
Mode Total in unit - Milliseconds
Output To msg.interval
The first message is stored as the baseline and dropped. Every subsequent message writes the elapsed milliseconds since the previous one to msg.interval.
ISC
Version: 0.4.6
Updated 1 month ago
9 in the last week
  • DelegatedConfigReferenceNode
  • TemporalTransformNode
  • TemporalDurationNode
  • temporal
  • time
  • date
  • duration
  • timezone
