@theotherwillembotha/node-red-prometheus 0.4.6
Prometheus metrics provider plugin for node-red-plugincore.
npm install @theotherwillembotha/node-red-prometheus
Prometheus metrics provider for Node-RED. Built on @theotherwillembotha/node-red-plugincore (bundled — no separate install required).
Provides:
  • Prometheus Metrics Config - a metrics provider config node that exposes a Prometheus-compatible scrape endpoint via the Webhook system
  • Counter, Gauge, Histogram, Summary metric types - available to any node using the plugincore @Metrics decorator
Either use the Manage Palette option in the Node-RED editor, or run the following command in your Node-RED user directory (typically ~/.node-red):
Prometheus Metrics Config node
A config node that acts as the Prometheus metrics provider for the plugincore @Metrics system. Once configured, it appears in the metrics selector dropdown of any node built with the @Metrics decorator.
Field Description
Name Display label for this config node
Webhook Path The HTTP path Prometheus will scrape (configured via the Webhook section)
Webhook Port The port the scrape endpoint listens on (configured via the Webhook section)
The scrape endpoint responds to GET requests with metrics in the standard Prometheus exposition format, using the content type from prom-client.
Metric Types
All metric types are created automatically when a node declares them via the @Metrics decorator. The following types are supported:
Counter
A monotonically increasing value (e.g. total requests processed).
@Metrics({ name: "requests_total", type: MetricType.Counter, description: "Total requests" })
private requests!: CounterMetric;
// usage
this.requests.inc();
Gauge
A value that can go up and down (e.g. current queue depth).
@Metrics({ name: "queue_depth", type: MetricType.Gauge, description: "Current queue depth" })
private queueDepth!: GaugeMetric;
// usage
this.queueDepth.inc();
this.queueDepth.dec();
this.queueDepth.set(42);
Histogram
Records observations into configurable buckets (e.g. request duration). Supports manual, linear, and exponential bucket configurations.
@Metrics({ name: "duration_seconds", type: MetricType.Histogram, description: "Request duration" })
private duration!: HistogramMetric;
// usage
this.duration.observe(0.25);
Summary
Records observations and calculates configurable percentiles (defaults: 0.01, 0.1, 0.9, 0.99).
@Metrics({ name: "response_size", type: MetricType.Summary, description: "Response size" })
private responseSize!: SummaryMetric;
// usage
this.responseSize.observe(1024);
Prerequisites
  • Node.js 18+
  • Node-RED 4+
  • A Prometheus server configured to scrape the endpoint
Repository
ISC
Version: 0.4.6
Updated 3 weeks, 6 days ago
58 in the last week
  • DelegatedConfigReferenceNode
  • PrometheusMetricsConfigNode
  • PrometheusDecodeNode
  • metrics
  • prometheus
