@theotherwillembotha/node-red-loki 0.4.6
Grafana Loki integration for Node-RED ( service config, logger, and LogQL query node). Built on @theotherwillembotha/node-red-plugincore.
npm install @theotherwillembotha/node-red-loki
Grafana Loki integration for Node-RED. Built on @theotherwillembotha/node-red-plugincore (bundled — no separate install required).
Provides three nodes:
  • Loki Service - shared connection config (URL, auth, tenant ID)
  • Loki Logger - ships structured log entries from any @Logger-decorated node directly to Loki
  • Loki Query - executes a LogQL query and emits the results as Node-RED messages
Either use the Manage Palette option in the Node-RED editor, or run the following command in your Node-RED user directory (typically ~/.node-red):
Loki Service
Shared connection configuration referenced by both the Loki Logger and Loki Query nodes.
Loki Service node
Field Description
Name Display label for this config node
URL Base URL of your Loki instance, including port (e.g. http://loki:3100)
Tenant ID Optional. Sent as the X-Scope-OrgID header for multi-tenant deployments. Leave blank for single-tenant mode.
Username Optional username for basic authentication
Auth Token Optional password or token for basic authentication
The Test Connection button pings the Loki instance with the current settings and reports success or failure inline; no need to save first.
Loki Logger
A logger config node that ships log entries from any node using the @Logger decorator directly to Loki over the HTTP push API.
Loki Logger Config node
Field Description
Level Minimum log level: Debug, Info, Warning, or Error
Loki Service The Loki Service config node to use for the connection
Template Handlebars template that shapes each log line (e.g. message:{{{json msg}}})
The Loki Logger appears in the logger selector of any node built with the plugincore @Logger decorator.
Loki Query
Executes a LogQL query against Loki on demand and emits the results as Node-RED messages.
Loki Query node
Field Description
Name Display label for this node
Query LogQL query; edited in a Monaco editor with syntax highlighting and snippet completions
Start Start of the time range. Accepts relative durations (1h, 30m, 7d) or absolute date strings
End End of the time range. Defaults to Now
Output Path Where in the output message to place each log line object. Defaults to msg.payload
Batch Mode When enabled, all results are collected into a single array message. When disabled (default), one message is emitted per log line
Query editor
The query field uses a Monaco editor with a custom LogQL language definition:
  • Syntax highlighting for stream selectors {app="nodered"}, pipeline stages, metric functions, and aggregation operators
  • Snippet completions for all major LogQL constructs ( trigger with Ctrl+Space)
  • Auto-closing brackets and quotes
Time range
The Start and End fields accept:
  • Relative - 1h, 30m, 7d, 2w (subtracted from now at query time)
  • Date/Time - 2024-01-01T00:00:00Z or any parseable date string
Output format
Each emitted message has the output path set to:
  "timestamp": "2024-01-01T00:00:00.000Z",
  "line": "the log message text",
  "labels": { "app": "nodered", "level": "error" }
In Batch Mode, a single message is emitted with the output path set to an array of the above objects.
Results are capped at 1 000 log lines or 10 MB of response data, whichever is reached first.
Message overrides
Property Description
msg.query Overrides the configured LogQL query
msg.start Overrides the configured start time
msg.end Overrides the configured end time
Example
A simple flow that queries Loki on demand and outputs results to the debug panel:
Example flow
A Request trigger fires the Loki Query node, which runs the configured LogQL query and passes each matching log line downstream to debug.
Prerequisites
  • Node.js 18+
  • Node-RED 4+
  • A running Grafana Loki instance reachable from your Node-RED host
Repository
ISC
Version: 0.4.6
Updated 1 month ago
7 in the last week
  • DelegatedConfigReferenceNode
  • LokiServiceConfigNode
  • LokiLoggerConfigNode
  • LokiQueryNode
  • loki
  • logging
  • grafana
  • observability
