@rosepetal/node-red-contrib-vlm-local 0.1.0
Node-RED node for open vision-language models running on the device with llama.cpp: image + prompt or tags -> detections
Node-RED node that runs an open vision-language model on the device itself and turns an image plus a prompt, or a list of tags, into detections.
vlm-local-inferencer is the local twin of vision-platform's
vlm-online-inferencer: same inputs, same msg.inference array entry for entry
(tag, confidence, raw_boxes, 2points, 4points, xywhr, cwh, all 0–1),
so a flow can swap one for the other.
- Offline once installed. The runtime is the public llama.cpp server image, pinned by digest; the weights come from public Hugging Face repos at a pinned commit, SHA-256 verified. No credentials on the device.
- One container per node,
nodered-vlm-local-<node id>, on a Docker-assigned127.0.0.1port, removed when the node is deleted. - Unload: keep the model loaded, or stop its container after each inference /
after N idle seconds (N from the panel,
msg,floworglobal); ≈3 s to load again. - Delete models from the panel; refused while a node or container uses them.
- Models are data:
catalog.jsonlists each model's files, coordinate format, parameters and measured VRAM. A device can add or override entries in/opt/storage/models/vlm/catalog.jsonwithout a release.
Requirements
An NVIDIA GPU available to Docker, the Docker socket, and /opt/storage mounted
at the same path in Node-RED and on the host (as on Rosepetal controllers, where
Node-RED runs with network_mode: host). Weights go to
/opt/storage/models/vlm/<model id>/ (override with VLM_LOCAL_MODELS_DIR).
Models
| id | VRAM (measured, RTX 3060) | Notes |
qwen3.5-9b-q4 |
6970 MB | Default. F1 .55 / IoU .87 on 10 client datasets |
qwen3.5-4b-q4 |
4390 MB | Smaller GPUs. F1 .46 / IoU .87 |
Layout
| Path | Contents |
nodes/vlm-local-inferencer.{js,html} |
The node and its edit panel |
catalog.json |
The offered models; the first entry is the default |
lib/catalog.js |
Packaged + device catalog, merged by id and validated |
lib/weights.js |
Resumable HF downloads, SHA-256 verification, one download per model |
lib/runtime.js |
The llama-server container: pull, start/reuse, health, removal |
lib/unloader.js |
Unload after N idle seconds, load again on the next request |
lib/llama.js |
One chat-completions request with the image and the JSON schema |
lib/detect.js |
Prompt, schema and parser, ported from the production labeler |
lib/gpu.js |
GPU name and memory from nvidia-smi |
lib/result-conversion.js, lib/image-input.js, lib/debug-image.js, resources/debug-image-canvas.js |
Copied unchanged from @rosepetal/node-red-contrib-vision-platform v1.4.16; keep in sync by copying |
test/fixtures/labeler.json is generated from the production Python labeler;
test/detect.test.js replays it so the port cannot drift.
Development
npm install
npm test
Apache-2.0
