@rosepetal/node-red-contrib-utils 1.1.10
Utility and I/O nodes for Node-RED, including array helpers and file saving.
npm install @rosepetal/node-red-contrib-utils
Utility and I/O nodes for Node-RED, focused on array assembly, queueing, safe debugging, promise aggregation, event loop monitoring, and file saving.
Array-Out Demo
Quick Start
Installation (Palette Manager)
  • Open Palette Manager -> Install -> search @rosepetal/node-red-contrib-utils.
Installation (npm)
Requirements
  • Node.js >= 16
  • Node-RED >= 1.0.0
  • sharp native addon (fetched via npm; builds from source if no prebuilt is available)
Node Type Prefix
All node types are prefixed with rp- to avoid collisions with other packages. In flow JSON you will see types like rp-array-in. In the editor, nodes appear under the "RP Utils" category with human-friendly labels.
I/O and Array Tools
Node Purpose
rp-array-in Tag incoming data with a position index for ordered array assembly.
rp-array-out Collect indexed data into ordered arrays with timeout handling.
rp-array-select Select array elements using index and slice syntax.
rp-queue Buffer messages, enforce output intervals, and drop stale or overflow items.
rp-save-file Save payloads to disk as image, JSON, text, or binary with auto-detection.
Async and Workflow
Node Purpose
rp-promise-reader Resolve arrays of promises, merge results, and record timing.
Utilities
Node Purpose
rp-clean-debug Debug output that sanitizes large payloads to keep the sidebar responsive.
rp-block-detect Event loop delay watchdog with live status and log warnings.
Project Structure
node-red-contrib-utils/
├── docs/nodes/          # Node documentation
├── nodes/               # Node-RED node implementations
│   ├── io/              # Array, queue, save-file nodes
│   ├── util/            # clean-debug, block-detect
│   └── promise-reader/  # promise-reader node
├── lib/                 # Shared utilities
└── assets/              # Documentation assets
Apache-2.0
Author
Rosepetal SL - https://www.rosepetal.ai
Version: 1.1.10
Updated 4 months ago
16 in the last week
  • rp-array-in
  • rp-array-out
  • rp-array-select
  • rp-queue
  • rp-rate-limit
  • rp-save-file
  • rp-clean-debug
  • rp-block-detect
  • rp-promise-reader
  • utilities
  • array
  • file
  • image
  • io
  • Nil Allue
  • Víctor González Bentué
