@rosepetal/node-red-contrib-system-monitor 1.0.0
System monitor dashboard widget for Node-RED Dashboard 2.
npm install @rosepetal/node-red-contrib-system-monitor
node-red-dashboard-2-system-monitor
System monitor widget for Node-RED Dashboard 2 (Linux-focused, NVIDIA GPU support).
System monitor widget preview
What it shows
  • CPU: per-core usage bars, average usage, tasks, threads, load average, uptime.
  • Memory: RAM and swap usage bars with used/total values.
  • Disk: mountpoint, filesystem, usage bar, used/total bytes, read/s, write/s.
  • Network: interface state, link capacity, down/s, up/s, RX total, TX total.
  • GPU (NVIDIA): utilization, VRAM usage, temperature, power, fan, p-state, GPU process VRAM.
  • Processes: htop-style table with PID, user, VIRT, RES, SHR, CPU, state type, command.
Design goals
  • Display-only widget (no inputs/outputs).
  • Non-blocking sampling with async reads.
  • Delta-based rates for CPU, disk, network, and process CPU.
  • Process table is filtered to the union of top 50 processes by VIRT, RES, SHR, and CPU for efficiency.
Requirements
  • Node.js (same version supported by your Node-RED runtime)
  • Node-RED >= 1.0.0
  • Node-RED Dashboard 2 (@flowfuse/node-red-dashboard)
  • Linux with /proc and /sys/class/net
  • Optional for GPU: nvidia-smi available in PATH
npm install node-red-dashboard-2-system-monitor
Or install from the Node-RED Palette Manager using the same package name.
Node configuration
The widget appears as system-monitor in the dashboard category.
Config fields:
  • Group: Dashboard 2 group where the widget is rendered.
  • Size: standard Dashboard 2 widget size.
  • Update interval (ms): refresh period (minimum effective value is 250 ms, default 1000 ms).
Notes
  • GPU section is auto-disabled when NVIDIA tooling is not available.
  • Network interface filtering ignores typical virtual/internal interfaces (loopback, docker, veth, etc.).
  • Disk section excludes pseudo filesystems.
Development
npm install
npm run build
npm run dev
Apache-2.0
Version: 1.0.0
Updated 9 months, 1 week ago
  • ui-system-monitor
  • dashboard
  • system
  • monitor
  • gpu
  • nvidia
  • linux
  • Victor Gonzalez Bentue
