@rosepetal/node-red-contrib-python-executor 1.0.4
A Node-RED node for executing Python code, similar to the function node but for Python
npm install @rosepetal/node-red-contrib-python-executor
Python into your Node-RED flows with a node that feels familiar, stays friendly, and keeps things fast when you need it.
Example
What You Get
  • Run small Python snippets whenever a message arrives.
  • Reuse your favorite Python tools without leaving Node-RED.
  • Choose between quick start-up or high-speed processing.
  • See clear status updates so you always know what is happening.
Before You Start
  • Install Python 3 on the machine running Node-RED.
  • Know where your Python interpreter lives (for most systems it is python3).
Node Options
  • Name – Optional label that appears on the canvas.
  • Python Path – The command Node-RED should run (for example python3 or a full path if you use a virtual environment).
  • Timeout – How long to wait for Python to finish before giving up. Useful to stop code that gets stuck.
  • Python Code – Your script. It always receives a message named msg, and whatever you return is passed along.
  • Hot Mode – Keeps Python processes running between messages for faster responses.
  • Workers – How many hot workers to run in parallel (only appears when Hot Mode is on). Use more workers when you expect bursts of messages.
  • Preload Imports – Optional lines that run once when each hot worker starts. Handy for heavier libraries you do not want to import on every message.
Cold vs Hot Mode
  • Cold Mode (default) – Starts a fresh Python process for every message. Great for occasional runs or quick experiments.
  • Hot Mode – Keeps a pool of Python workers ready. Messages are handled much faster after the first one. Best for frequent or time-sensitive flows.
Typical Flow
  1. Drop the python executor node into your flow.
  2. Connect an Inject node (input) and a Debug node (output).
  3. Add a short script, for example:
    msg['payload'] = f"Hello, {msg.get('payload', 'world')}!"
    return msg
  4. Deploy and trigger the flow. Adjust options as needed.
Context & Warnings
You can read/write Node-RED context from Python and emit warnings:
count = flow_ctx.get("count", 0)
flow_ctx.set("count", count + 1)
node.warn(f"count is now {count + 1}")
return msg
  • Use flow_ctx for flow context and global_ctx for global context.
  • Context values should be JSON-serializable.
Working with Images
Rosepetal images travel as a dict {data, width, height, channels, colorSpace, dtype}. Two helpers are injected into every node automatically — no import or boilerplate — so you can round-trip through OpenCV/NumPy:
import cv2
img = rp_to_cv(msg["payload"])          # -> BGR uint8 ndarray, ready for cv2
img = cv2.GaussianBlur(img, (7, 7), 0)
msg["payload"] = rp_from_cv(img, like=msg["payload"])
return msg
  • rp_to_cv(obj) returns a NumPy array. RGB/RGBA inputs are reordered to BGR/BGRA (OpenCV's convention); grayscale stays 2-D. It honors colorSpace and dtype, and accepts data as raw bytes, a Node Buffer, a list, or base64.
  • rp_from_cv(arr, like=obj) returns a Rosepetal image dict. The array is assumed BGR and reordered back to RGB. Pass the source dict as like= to preserve its colorSpace label.
  • data comes back as raw bytes, so it rides the shared-memory fast path in hot mode (no base64 bloat).
Benefits At A Glance
  • Familiar: Works just like the standard function node, only in Python.
  • Flexible: Supports both simple scripts and larger libraries.
  • Fast: Hot mode cuts response time dramatically for repeat work.
  • Clear: Status messages and notifications help you see what is working and what needs attention.
  • Binary Friendly: Hot workers stream large Buffers through shared memory instead of JSON, so images and other blobs stay fast.
Handling Large Binary Payloads
  • Hot workers drop large Buffers into /dev/shm (or your system temp dir) and hand Python the file handle so bytes never touch JSON.
  • Python can return bytes, bytearray, or memoryview; the worker writes them back to shared memory and Node converts them to Buffers automatically.
  • If the filesystem path is unavailable, the system falls back to base64 as a safety net (slower but still works).
  • Temporary blobs are cleaned up as soon as each request finishes—no manual housekeeping required.
  • The optimization is automatic—just enable hot mode when you expect heavy binary traffic.
Enjoy mixing Python logic into your Node-RED projects without extra fuss. When you are ready for more performance, flip on Hot Mode and keep building.
Version: 1.0.4
Updated 3 months, 2 weeks ago
7 in the last week
  • python-executor
  • python-environment
  • python
  • executor
  • function
