@rosepetal/node-red-contrib-image-tools 1.6.4
Node-RED Image Processing Toolkit
npm install @rosepetal/node-red-contrib-image-tools
A comprehensive Node-RED package providing 18 specialized nodes for high-performance image processing using C++ OpenCV backend. Perfect for computer vision workflows, batch processing, and automated image manipulation.
Demo
🚀 Quick Start
Installation (users)
From Node-RED (Palette Manager)
  • Open Palette Manager → Install → search @rosepetal/node-red-contrib-image-tools.
From npm (CLI, default)
Development installation (build from source)
For contributors or platforms without a prebuilt binary:
./install.sh
# or manual steps:
cd rosepetal-image-engine && npm install && npm run build
cd ../node-red-contrib-image-tools && npm install
cd ~/.node-red && npm install /path/to/node-red-contrib-image-tools
npm installs fetch prebuilt binaries for common platforms; build from source only if you are developing or a prebuilt is unavailable.
Requirements
  • Node.js 16+ with node-gyp support
  • OpenCV 4.x (auto-detected via pkg-config)
  • C++ compiler with C++17 support
📋 Node Categories
I/O Nodes - Data Flow Management
Node Purpose Key Features
image-in Load images from filesystem JPEG/PNG/WebP/etc. support, Sharp backend
image-out Save images with timestamp naming Auto-naming, overwrite protection, format conversion
Transform Nodes - Image Processing
resize Scale images with aspect ratio control Proportional scaling, multiple modes
rotate Rotate images with custom padding Sub-pixel precision, background colors
crop Extract regions with pixel/normalized coords Dynamic coordinates, bounds checking
padding Add configurable margins Color customization, flexible sizing
filter Apply enhancement filters Blur, sharpen, edge, emboss, Gaussian
draw Overlay points and lines on images Normalized coordinates, typed inputs, C++ compositing
Mix Nodes - Image Composition
concat Combine images horizontally/vertically Direction control, padding strategies
mosaic Position images on canvas Coordinate positioning, manual placement
advanced-mosaic Complex layouts with custom positioning Pixel-perfect control, layering
Blend Nodes - Advanced Compositing
blend Alpha blend two images with opacity Background removal, color tolerance
add-mask Apply polygon-based masks to regions Coordinate arrays, mask strength control
Specialized Nodes - AI/ML Integration
cropBB Extract crops from AI bounding boxes Object detection integration, confidence filtering
image-align Ultra-fast image alignment using ECC algorithm Translation correction, speed presets, real-time processing
Architecture & Performance
Two-Tier Design
  • JavaScript Layer: Node-RED integration, validation, I/O handling
  • C++ Layer: OpenCV-powered image processing for maximum performance
Performance Benefits
  • Faster! than pure JavaScript implementations
  • Parallel processing for array operations
  • Memory efficient with optimized algorithms
  • Async operations with real-time performance timing
Image Data Format
  data: Buffer,        // Raw pixel data
  width: number,       // Image width in pixels
  height: number,      // Image height in pixels
  channels: number,    // Channel count (1, 3, 4)
  colorSpace: string,  // "GRAY", "RGB", "RGBA", "BGR", "BGRA"
  dtype: string        // "uint8" (standard)
🛠️ Development
Project Structure
node-red-contrib-image-tools/
├── docs/nodes/          # Individual node documentation
├── nodes/              # Node-RED node implementations
│   ├── io/             # I/O nodes
│   ├── transform/      # Transform nodes
│   ├── mix/            # Composition nodes
│   ├── blend/          # Blending nodes
│   └── specialized/    # AI/ML nodes
├── lib/                # Shared utilities
└── assets/             # Documentation assets
rosepetal-image-engine/  # C++ processing engine
├── src/                # OpenCV implementations
├── binding.gyp         # Node.js addon configuration
└── package.json
Adding New Nodes
  1. Implement C++ processing in rosepetal-image-engine/src/
  2. Export function in src/main.cpp
  3. Create Node-RED wrapper in appropriate nodes/ category
  4. Add comprehensive documentation following existing patterns
🚨 Troubleshooting
Common Issues
  • Build Failures: Ensure OpenCV 4.x installed and pkg-config available
  • Missing Nodes: Check Node-RED installation path and package registration
  • Performance Issues: Verify C++ addon built with optimization flags
  • Memory Problems: Process large images in smaller batches
Performance Tips
  • Use raw format for processing chains (fastest)
  • Process arrays when possible for parallel execution
  • Choose appropriate output formats for your destination
  • Monitor node status displays for timing information
🤝 Contributing
  • Issues: Report bugs and feature requests via GitHub
  • Pull Requests: Contributions welcome for new nodes and optimizations
  • Documentation: Help improve guides and examples
📄 License
This project is part of the Rosepetal development toolkit for Node-RED image processing applications.
💡 Pro Tip: Start with simple single-node workflows, then combine them into complex processing pipelines as you become familiar with the image format and node interactions.
Version: 1.6.4
Updated 2 months, 1 week ago
Rating: 5.0 2
230 in the last week
  • rp-heat-diff
  • image
  • opencv
  • performance
  • Nil Allue
