@rosepetal/node-red-contrib-barcode-reader 1.3.0
Rosepetal multi-decoder barcode scanner with ZBar, ZXing, and Quagga2 support
npm install @rosepetal/node-red-contrib-barcode-reader
Multi-decoder barcode scanner for Node-RED with ZBar, ZXing, and Quagga2 support.
Version: 1.0.0 License: Apache-2.0 Platform: Linux (Ubuntu/Debian)
Overview
A sophisticated barcode detection system featuring:
  • Three decoder backends: ZBar (C++), ZXing (C++), Quagga2 (JavaScript)
  • Three preprocessing methods: Original, Histogram Equalization, Otsu Threshold
  • Block-based architecture: Flexible combinations of decoders and preprocessing
  • Two execution modes: Parallel (maximum detection) and Sequential (fast with fallback)
  • Automatic deduplication: Intelligent merging of redundant detections
  • Normalized coordinates: All results in 0-1 relative range
Feature Description
Multi-decoder Combine ZBar, ZXing, and Quagga2 in configurable blocks
Preprocessing Enhance images before decoding for better results
Parallel Mode Run all blocks concurrently, merge and deduplicate results
Sequential Mode Run blocks in order, stop at first successful detection
Array Support Process single images or arrays of images
Performance Tracking Execution time displayed in Node-RED editor
Relative Coordinates Output normalized to 0-1 range for any image size
Requirements
Build Dependencies (source builds only)
Package Purpose
libzbar-dev ZBar barcode library
libzxing-dev ZXing barcode library (or build from source)
libopencv-dev OpenCV image processing
build-essential C++ compiler toolchain
node-gyp Native addon build tool
Prebuilt binaries bundle OpenCV, ZBar, and ZXing on supported platforms. Install these packages only if you are building from source or using an unsupported platform.
Runtime
  • Node.js: >= 14.x
  • Node-RED: >= 1.0.0
  • OS: Linux (Ubuntu/Debian recommended)
Palette / npm install (recommended)
Install from the Node-RED palette or via npm:
npm will attempt to fetch a prebuilt native addon for supported platforms. Prebuilt binaries bundle OpenCV/ZBar/ZXing; system libraries are only required for source builds or unsupported platforms.
Build from source (Debian/Ubuntu)
cd node-red-contrib-barcode-reader
bash INSTALL.sh
The script will:
  1. Install ZBar, ZXing, and OpenCV libraries
  2. Build ZXing from source if package not available
  3. Build the C++ addon and install the Node-RED package dependencies
Manual Installation (source build)
# Install dependencies (Debian/Ubuntu)
sudo apt-get update
sudo apt-get install -y libzbar-dev libopencv-dev build-essential
# Install ZXing (if available in repos)
sudo apt-get install -y libzxing-dev
# Or build ZXing from source
git clone https://github.com/zxing-cpp/zxing-cpp.git
cd zxing-cpp && git checkout v2.3.0
mkdir build && cd build
cmake -DCMAKE_INSTALL_PREFIX=/usr -DBUILD_SHARED_LIBS=ON ..
make -j$(nproc) && sudo make install
# Build the addon
cd /path/to/node-red-contrib-barcode-reader/barcode-engine
npm install
# Install the Node-RED package dependencies
cd ../node-red-contrib-barcode-reader
npm install
# Optional: install into Node-RED
npm install /path/to/node-red-contrib-barcode-reader/node-red-contrib-barcode-reader
Node-RED Configuration
Adding to Palette
The node registers automatically as barcode-reader in the Node-RED palette under the input category.
Node Configuration
Setting Description Default
Name Node instance name -
Input Message property for input image msg.payload
Output Message property for results msg.payload
Execution Mode parallel or sequential parallel
Blocks Array of decoder+preprocessing combinations 1 block
Block Configuration
Each block specifies:
  • Decoder: zbar, zxing, quagga2, or rp-projection
  • Preprocessing: original, histogram, or otsu (not used by rp-projection)
  • Options: Decoder-specific settings (e.g. formats allowlist; minVotes and stripWidth for rp-projection)
Decoders
Decoder Type Formats Speed Options
ZBar C++ Native QR, Code-128, EAN, UPC, Code-39 Fast None
ZXing C++ Native All major 1D/2D formats Medium formats
Quagga2 JavaScript 1D barcodes (Code-128, EAN, UPC, Code-39, Codabar) Slower Reader selection
Rosepetal Projection C++ Native 1D barcodes Slow (50-300 ms) formats, minVotes, stripWidth
ZBar
  • Fastest decoder for common formats
  • Excellent QR code detection
  • No configuration options
ZXing
  • Most comprehensive format support
  • Thorough scan and rotation handling always on (matches zxing.org defaults)
Quagga2
  • Pure JavaScript implementation
  • No native compilation required
  • Best for 1D linear barcodes
Rosepetal Projection (rp-projection)
  • For noisy or low-resolution 1D codes the other decoders miss (down to ~1.5 px per module)
  • Expects a crop of a single barcode (e.g. a detector output); orientation is estimated automatically
  • Straightens the crop, averages bands of pixels into clean 1D profiles, reads each profile with ZBar and ZXing and accepts a value only when at least minVotes profiles agree (default 3). Stops early once a value has 3× minVotes and leads every other value by 3×; the vote count at that point is returned as the result quality
  • Band height is automatic (12% of the bar height, 8-48 px). Advanced: options.stripWidth in the flow JSON overrides it in px (not exposed in the editor)
  • Gray plus each color channel are tried, so chromatic aberration on one channel is harmless
  • No preprocessing step and 1D formats only; slower, so use it as a fallback block
Preprocessing Methods
Method Description Best For
Original Grayscale conversion only High-quality images, fast processing
Histogram Contrast enhancement via histogram equalization Poor lighting, low contrast
Otsu Binary threshold after histogram equalization Very low contrast, faded barcodes
Input Format
The node accepts multiple image formats:
Rosepetal Bitmap (Recommended)
  data: Buffer,           // Raw pixel data
  width: 640,
  height: 480,
  colorSpace: "RGB",      // "GRAY", "RGB", "BGR", "RGBA", "BGRA"
  dtype: "uint8"
Raw Bitmap
  data: Buffer,
  width: 640,
  height: 480,
  channels: 3             // 1 (grayscale), 3 (RGB/BGR), 4 (RGBA/BGRA)
Encoded Image
Buffer  // JPEG or PNG encoded data (auto-detected)
Array Input
[image1, image2, image3]  // Array of any format above
Output Format
Single Image Result
    format: "QR-Code",
    value: "https://example.com",
    box: {
      angle: 15.2,                        // Rotation in degrees
      center: { x: 0.5, y: 0.5 },         // Relative center (0-1)
      size: { width: 0.2, height: 0.2 }   // Relative size (0-1)
    corners: [                             // 4 corner points (0-1)
      { x: 0.4, y: 0.4 },
      { x: 0.6, y: 0.4 },
      { x: 0.6, y: 0.6 },
      { x: 0.4, y: 0.6 }
    detectedBy: [                          // All successful detections
      "zbar_original",
      "zxing_histogram"
Array Input Result
  [/* image1 results */],
  [/* image2 results */],
  [/* image3 results */]
Coordinate System
All coordinates are normalized to 0-1 range:
  • x: 0 = left edge, x: 1 = right edge
  • y: 0 = top edge, y: 1 = bottom edge
To convert to pixels: pixelX = x * imageWidth
Usage Strategies
Maximum Detection (Parallel)
Use multiple blocks with different decoder/preprocessing combinations:
Execution Mode: parallel
Blocks:
  1. ZBar + Original
  2. ZXing + Original
  3. ZBar + Histogram
  4. ZXing + Histogram
  5. ZXing + Otsu
All blocks run concurrently. Results are merged and deduplicated by barcode value.
Optimized Performance (Sequential)
Order blocks from fastest to most thorough:
Execution Mode: sequential
Blocks:
  1. ZBar + Original        (fastest)
  2. ZXing + Original       (if ZBar fails)
  3. ZXing + Histogram      (if poor contrast)
  4. ZXing + Otsu           (last resort)
Stops at first successful detection for faster processing.
QR Code Focus
Blocks:
  1. ZBar + Original
  2. ZXing + Histogram
1D Barcode Focus
Blocks:
  1. ZBar + Original
  2. Quagga2 + Histogram
  3. ZXing + Otsu
Noisy / Low-resolution 1D Crops
Blocks:
  1. ZBar + Original            (fast path)
  2. Rosepetal Projection       (only runs when block 1 finds nothing)
Feed the node a crop containing one barcode. Restrict Formats to the symbology you expect to keep the vote clean.
Programmatic API
For use outside Node-RED:
const barcode = require('@rosepetal/node-red-contrib-barcode-reader');
// Preprocessing (returns grayscale cv::Mat as Rosepetal bitmap)
const gray = barcode.preprocess_original(inputMat);
const enhanced = barcode.preprocess_histogram(inputMat);
const binary = barcode.preprocess_otsu(inputMat);
// Decoders (require grayscale input, return JSON string)
const zbarResult = barcode.decode_zbar(gray);
const zxingResult = barcode.decode_zxing(gray);
// Parse results
const barcodes = JSON.parse(zbarResult);
console.log(barcodes.results);
// Utilities
const resized = barcode.resizeImage(inputMat, 50);  // 50% size
const converted = barcode.convertToMat(anyInput);   // normalize input
Decoder Result Format
  "results": [
      "type": "QR-Code",
      "data": "decoded content",
      "points": {
        "x1": 100, "y1": 100,
        "x2": 200, "y2": 100,
        "x3": 200, "y3": 200,
        "x4": 100, "y4": 200
Troubleshooting
Build Errors
These errors only apply to source builds (when no prebuilt binary is available).
"Could not load the barcode native addon"
  • If no prebuilt binary is available for your platform, install system deps and run cd barcode-engine && npm run rebuild
"Cannot find -lzbar"
sudo apt-get install libzbar-dev
"Cannot find -lZXing"
# ZXing not in repos, build from source
sudo ldconfig
"Cannot find opencv2/opencv.hpp"
sudo apt-get install libopencv-dev
node-gyp errors
sudo apt-get install build-essential python3
npm install -g node-gyp
Runtime Errors
"Module not found"
npm run rebuild
No barcodes detected
  • Try different preprocessing methods
  • Add a ZXing block alongside ZBar (different decoders catch different cases)
  • For noisy or low-resolution 1D crops, add a Rosepetal Projection block as a fallback
  • Check image quality and barcode size
  • Ensure barcode is not too small (< 50px) or too large
Performance Issues
  • Use Sequential mode for faster response
  • Reduce number of blocks
  • Resize large images before processing
  • Use ZBar for simple cases (fastest)
Supported Barcode Formats
1D Barcodes
  • Code-128
  • Code-39
  • EAN-13, EAN-8
  • UPC-A, UPC-E
  • Codabar
  • ITF (Interleaved 2 of 5)
2D Barcodes
  • QR Code
  • Data Matrix
  • PDF417
  • Aztec
Apache-2.0
Copyright (c) Rosepetal SL - https://www.rosepetal.ai
Third-Party License Compliance
This project uses ZBar (LGPL-2.1), ZXing-cpp (Apache-2.0), OpenCV (Apache-2.0), and Quagga2 (MIT) via npm. Prebuilt binaries statically link OpenCV/ZBar/ZXing for portability. Source builds link against system libraries; if you need to replace ZBar to exercise LGPL rights, build from source. Third-party license texts are included in THIRD_PARTY_NOTICES.
Credits
This project uses the following open-source libraries:
Author
Rosepetal SL https://www.rosepetal.ai
Version: 1.3.0
Updated 1 month, 3 weeks ago
Rating: 5.0 7
26 in the last week
  • barcode-reader
  • barcode
  • zbar
  • zxing
  • quagga2
  • scanner
  • Víctor González Bentué
